- Aug 29, 2010
- 891
- 1,379
- Hymer Exsis t564
- Since Sept 2010
Some Funsters will be aware that I have just had 2 weeks in hospital. As this started immediately on return from a short trip away in the van, I was unable to carry out the usual drain down etc. In all the drama of being in hospital, I missed the frosty overnights and didn't warn the missus.
Yesterday I inspected the van and found that the dump had not triggered or didn't look as though it had but when I ran the taps there was spluttering and hissing etc. Fresh water still showed 50% but it became clear that the boiler reservoir was empty. Cold taps normal. Moreover, when the taps were opened on hot only, water ran out copiously from underneath in the vicinity of the dump exit.
As I have said, the dump valve appeared to be in the 'closed' position but was physically open.
I operated the dump valve mechanism, open/close several times and tried running the hot taps again.
Eventually, all returned to normal, by which time the fresh water tank was showing 25%.
So, all fixed? Still OK this morning but what happened?
Water dumping without valve visibly triggering.
Queer!
Queer!
