Not Tyres Again!
Rubberman
Darlington, UK
Adria Twin
Since 2017
Hi, I am a newbie here so please be gentle.
I have read a number of threads here regarding van vs camper tyres. I have Michelin CP tyres and they make the ride harsh IMO.
My question is…..has anyone experienced van tyres actually deforming when left standing for a couple of months as my van does over winter? I know CP tyres are designed to counteract this but is it a real issue?
Thanks in advance.
My van is on van winter tyres, and has periods where it has stood for a couple of months. Wouldn’t think much longer than that though. We try to do something each month, but no tyres issues. All positive for us.
What pressures are in the tyres
Do you mean mine of the OP?
Mine are as recommended by the tyre manufacturer:
56 psi Front, axle load 1930kg
69 psi Rear, axle load 2300 kg
Will I need to change the spare as well? It has never been used. It is a Michelin Agilis CP. I am considering the Toyo Observe and Conti VanContact.
I did not when I changed to a set of Yokohama last year. My thinking was, the spare has never had direct sunshine so the degradation from UV was negligible. I am happy to run it for as long as it would take me to source a replacement Yokohama.
Geoff
I will be fitting my own. I don’t trust others.
Check the pressures before you spend any money. When I picked my van up it had 80psi all round, and rattled our teeth summat rotten. After getting advice on here and doing some research, it's running on 65 in the front and 80 in the back and is a much better ride.
Thanks Trevor. Are you using Michelin CP tyres because Michelin don’t seem to recommend lower pressures based on axle weights like Continental do. I will try lower pressures but many say it makes little difference on the Michelins.
Hi, I have Mich campers on from new done 34000 5.5 years old now 4 mm tread left 58 lb front and 60 rear and I will replace when worn out none of this 5 Yr malarkey, will go for toyo observe when required.Bill
Thanks in advance.
Apologies if you have already seen this, but this article might help: https://www.caravanguard.co.uk/news/caravan-guard-guide-on-motorhome-tyres-11984/
Also a point to consider is because CP rated tyres have reinforced side walls (stating the obvious) but . .
Reinforced side walls also help minimize any side to side rocking movement in the van when parked and your in it.
Standard van tyres may not provide this effect as much.
But have you checked when the tyre was manufactured?
Tyres could easily be a year or more older than when the van was registered.
While I agree with not rushing out to replace at five years old I do inspect them much closer as they get older.
Any sign of cracking starting between the tread and they go.
I only mention this as I was out having four replacements fitted this morning. Pocket £524 lighter :(
Loads of tread left but cracking starting.
All part of the fun of motor homing ;)
Just checked, Continental.
We have Conti Vancontact Eco tyres on our T6.1 PVC, and have found them pretty good for economy, noise etc. They managed well in snow last winter in Scotland too!
That is what I have on mine TOYO. 60psi all round and no problems.
Replaced the Michelin CP's at 3 years & 25,000 fronts were down to 4mm rear to 4.5mm.
Couldnt stand the complete lack of grip & rock hard ride. Lowerng the pressure didn't make any difference.
By comparison the Toyo's are dream, they do wear faster & mpg is down a couple of mpg. Small price for decent grip & it's offset by the tyres being 50 quid cheaper for each tyre.
No rocking in my van I'm afraid.. !😥😥😥
Agree. Toyo much cheaper then exorbitant price of Michelin. Toyo give a good ride and when they need to be changed it will not break the bank. The only snag about them is that they are a bit harder.
