Nordellectronica NE 102C no display unless connected to mains. (1 Viewer)
rickjohnston
5
CI Cipro Garage
Since 2018 (newbie"
Not sure how it happened, but getting the motorhome out of winter storage, the NE 102C display panel was blank. I assumed the house bank was depleted. It started fine, drove it home and plugged into the mains. The display showed low voltage, and the switches worked. Next day batteries are at 13.5 and when removed from mains the display goes blank and the switches are inop. No 12v useable.
Any Ideas?
Many thanks in advance.
Riverbankannie
10,670
62,298
Bristol
IH 630 RL PVC
:hiya:
I assume from the way you have written the above that the display showed 13.5 v whilst still hooked up to EHU. Once disconnected your hab battery could be still dead if it’s been left over the winter.
Others will be along soon to tell you how to check it.
R
rickjohnston
5
CI Cipro Garage
Since 2018 (newbie"
I've put a meter on the hab batteries, they show 13.3v but there is no display and no 12v for interior lights and pumps. I've checked all the fuses I can find. no "opens".
TerryL
6,208
8,220
North East
Low Profile
Try a simple reset before you do anything else.
Carefully prize off the bezel surrounding the screen then unscrew the unit. Carefully remove and take off the electrical connecting plug on the back and leave for a couple of minutes.
Now put it all back - this usually solves problems with this unit.
If this doesn't work unfortunately you can't buy a replacement but there is a firm that can repair them, can't remember the name but someone will come up with it shortly.
R
rickjohnston
5
CI Cipro Garage
Since 2018 (newbie"
Great, thanks, I'll give it a try.
R
rickjohnston
5
CI Cipro Garage
Since 2018 (newbie"
Well,, no joy.. but I did take a few pictures for reference.
Jul 5, 2013
11,759
13,768
Since 2013
The 13.5V is probably the charge voltage. Unplug the mains, and then check your battery voltage using a multi meter on the terminals. If you have left the battery uncharged over the winter it could well be goosed.
