Non invasive moisture meter (1 Viewer)
Saltings
228
33
Buckinghamshire, U.K.
Chasson C626 Flash
since 2115
Has anyone had experience with the following moisture meter sold on Amazon:
Extech Instruments MO280 Pin Less Moisture Meter
by
Am thinking of getting a moisture meter just to keep an eye on the MH.
Saltings
Jun 10, 2013
411
267
Sussex
van conversion
Festivals
Good idea Brian, please put a link in here when you've done the research! We've just moved from a campervan to motorhome and not particularly considered damp before but I also would like to monitor it.
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
Very odd, a quick run through ebay finds very little in the way of non penetrating damp meters. Here is one similar in use to mine but not identical......
Saltings
Saltings
228
33
Chasson C626 Flash
since 2115
have dropped them a line to see if it will measure moisture in a sandwich wall with g/fibre each side.
Welsh girl
3,658
3,036
Globecar
Since 2004
This is the one I have, I've gone through the van testing it and had a professional damp test done to be sure and the readings are identical.
Thanks to funstersfor for previous recommendations.
Saltings
Saltings
228
33
Chasson C626 Flash
since 2115
This is the reply I received from those selling that model on Ebay. But bearing in mind your tests it appears it is OK?
New message from: beepmax (1,311)
Hi there,
Thanks for your msg.
Sorry but maybe it can't work like you said.
Sorry again.
Any concern,feel free to contact us.
We are ready to help.
Regards
Anna
Customer Assist Team
Mon-Fri: 9AM-5PM
Reply
YOU:
Re :Digital LCD Wood Timber Induction Moisture Meter Damp Detector Humidity Tester.
is this suitable for use in motor homes/caravans to measure moisture in a sandwich construction. External and internal walls are glassfibre with sandwich insulatioin between the walls?
Kind regards
