Tincataylor
- Jul 9, 2012
- 639
- 1,360
- Coachbuilt
- Never leave a campsite with your clothes line tied to a lamp post.
I have a problem with the Sureflo water pump in our Nuevo which perhaps someone on here has an answer to. The old pump was getting a bit noisy so I purchased and fitted a brand new one to be on the safe side. Its performance on the cold water system is perfect and as soon as the tap is closed it stops immediately. However, on the hot water system it continues to run once the tap is closed for about 5 seconds and ends with about another 3 seconds with a really loud pulsing noise, and it feels like it’s trying to shake itself loose.
I have consulted the book of knowledge and can confirm that there are no blockages in the system and that the pump filters are clean. I have also tried adjusting the pump cycling adjustment screw and it makes absolutely no difference where I set it to the pump operation. Looking at the pipe layout diagram I am at a loss to see what it is between the hot and cold pipework that is making a difference unless there is a large air lock in the water heater and it is the pump trying to compress this air that causes it to run on when the hot water tap is closed. I can find no reference to a bleed valve at the top of the water heater.
Any bright ideas would be much appreciated.
