- Feb 4, 2022
- 10
- 1
- Burstner Argos 747-2
Hi all,
New member here.
Would love your thoughts on a water issue in Barry, our 2007 Burstner Argos 747-2.
So there's no water coming through any of the taps - kitchen, washroom or shower.
Water pump is on.
There is water in the tank.
Water pump is running when taps are turned on.
Thinking it was an airlock, I removed the shower head from the shower, turned shower on to activate pump and sucked on the shower hose - water did indeed come through, but stopped when I stopped sucking.
Checking the washroom and kitchen taps, water was now in these taps, but only a little and it stopped running after a few seconds.
Checking the fresh water tank and pump (which is submerged), I can't see any obvious leaks in the pipework, and when I leave a tap open (and therefore the pump running) I can't see the water level going down in the tank.
Is it an issue with the pump? It's as if the pressure is too low to manage to run the water through the taps?
I'm a bit stumped here, and would love your thoughts.
Cheers,
Colin
New member here.
Water pump is on.
Cheers,
Colin
