no signal cannot auto tune new tv (1 Viewer)
michael cant
9
eldiss boxer
3 months
Hi Everyone.
I have an R reg Eldiss envoy camper van.not gone away in it yet but just bought a freeview tv for it and an inverter box so it can take the voltage on the tv. Tried to tune in channels by auto tuning and keeps coming up with no signal.Anyone have any ideas what I can do please,seems local tv engineers do not know as they do not know about camper vans,This is my first camper van and due to go away in 2 weeks.
Many thanks
Mick
Jul 5, 2013
11,516
13,346
Since 2013
You need an aerial to pick up freeview. Pregerably choose a directional one with signal amplifier. Then you need to point it in the cortect direction. Some have built in lights to show the strength of the signal. If not you will need to buy a signal strength meter.
lunarman
2,134
2,408
South Glos
since 1994
Another question about the aerial. Is it compatible with a digital signal? Given the age of the van it could be analogue only.
42,977
47,173
The aerial MUST point DIRECTLY at the local TV mast.
A little to left or right and you won't get a strong enough signal.
If you only get one or two poor channels you need to twist the aerial through 90° from flat to vertical or visa versa.
EVERY TIME you move from one place to another you have to point the aerial to the local mast again.
Pain in the arse but has to be done.
Also, make sure the signal amplifier, usually in an overhead locker or wardrobe, is switched on.
42,977
47,173
Another myth..... All aerial will get a digi signal, some better than others.
At home we have a 30 year old wire set top aerial in the bedroom.
Picks up all digi channels for our area.
Jan 19, 2014
9,043
23,613
Derbyshire
Elddis Accordo 105
since 2014
If there is a signal amplifier make sure its on. Our Elddis van has got one in the wardrobe.
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
2018, Apache 634 150 Auto
Since 2015
We see Ariels pointing in all directions. I used to point mine in the direction of the majority. Never once did I change it from Horizontal to Vertical and never had any issues (y)
Feb 25, 2018
5,484
12,102
Essex
Adria 670 SLT
I would test the tv and receiver in the house. It may have nothing to do with van as to why youre not getting a signal
42,977
47,173
Those pointing in any old direction are the ones reading a book.
They are the ones who tried to find the mast but couldn't.
They are the ones who gave up.
If you ain't pointing at the mast, you ain't watching tele......unless you're happy watching a really shite picture with more pixelated screen than picture.
The majority of masts today use the vertical signal but there are still some repeater masts using the horizontal signal.
Why do you think m/h aerial manufacturers spend extra fitting a little crank handle to change the polarity.
They would fit if it wasn't needed.
You will get some channels on the wrong polarity but you'll miss out on so many more.
Saying that, some people don't care as long as there's something that resembles a TV picture.
M
michael cant
9
eldiss boxer
3 months
I was told the ariel is built in to the van and is on the roof.I automatically assumed buying a co ax cable would get a signal.I ust need to buy something else according to some of the answers on here.
M
michael cant
9
eldiss boxer
3 months
did you need to buy an indoor Ariel as well as using the one built into the van?
M
michael cant
9
eldiss boxer
3 months
brand new tv and works fine in the house.so not sure if I need an indoor ariel if so which would be best to buy?
M
michael cant
9
eldiss boxer
3 months
so if it is not compatable with the van what tv would be best to buy?
Jan 11, 2010
2,693
8,857
Chester
Auto-trail
Well that`s our 13th year & still loving it.
Avtex......
M
michael cant
9
eldiss boxer
3 months
Silly question....
Do you have an ariel?... is it connected... is it pointing in right direction?...
only have the ariel that is built in to the van,so I bought a co ax lead and thought it would work,but keeps saying no signal .
M
michael cant
9
eldiss boxer
3 months
Silly question....
so basically get on the roof of the van and keep moving the ariel until you get a signal? I do not have an indoor ariel
tonka
10,676
21,053
Cannock, Staffs
A class Burstner 800
Since 2000
You have eliminated the TV by testing in home. (y)
So now look on the roof for an actual aerial.
If one is there then next look in cupboards as almost all of these type use an amplifier. This will have aerial in from the roof and aerial out to the TV. It will be operated by 12v so should have a light on it.
A bad connection anywhere on the plugs, faulty amplifier or faulty aerial could be the reason for no signal. Start with the obvious and check all plugs are in and take aerial plugs apart to check connections are not shorting or broken.
M
michael cant
9
eldiss boxer
3 months
not sure if I have an ariel amplifier.how would I find that?
Feb 16, 2017
358
435
Southampton
AT tracker 2002
On n off fer years
My old van has a round aerial on the roof, it picks up all the free view channels as long as the signal booster fitted in a cupboard is on .the signal booster only works if the habitation electrics are on by the way. I used to use an inverter and take the house TV with me! Now I've got a 12v cello tv that just plugs in to the cigarette lighter socket.hope you get it sorted out for your trip.
Lenny HB
50,292
138,949
On the coast in West Sussex
Hymer B678 DL
No such thing as an analogue or digital aerial any tv aerial will pick both types of signal just marketing BS.
