Talking about changing the thermocouple on the grill of Thetford Triplex oven. It's right at the back. Looks like it could all go pear-shaped. Will I regret trying it myself?
Perhaps you will...but it might make a great read.....awaiting your post....Talking about changing the thermocouple on the grill of Thetford Triplex oven. It's right at the back. Looks like it could all go pear-shaped. Will I regret trying it myself?
In order to change the thermocouple?According to this the oven has to be removed
That's why I'm asking..........‘Presumably…’ the scariest word in the English language
Oh dear, sounding worse by the minute. And would it need to be reconnected by a Gas-Safe engineer?If like mine it will be a solid pipe which you have to disconnect from the manifold to give you some movement so that you can then disconnect from gas valve to slide oven out.
That’s what I readIn order to change the thermocouple?
I've done nothing but read reams of stuff all day. I was trying to clarify your suggestion. Sorry to have burdened you.That’s what I read
Maybe you should read it too ?
That's what I was hoping, but I will have to check the back of the oven from outside. I think I'll be able to see it, but not sure.some will have a coil of pipe behind to allow enough movement to dissconnect
