Nice little van up for auction
Look out for the rust.
Previous MOT in Feb 19 looks a little worrying .
  • Parking brake efficiency less than 50% of the required value (1.4.2 (a) (ii))
Repair immediately (major defects):​
  • Driver's door cannot be opened from inside the vehicle (6.2.3 (a))
  • Offside Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced sill holed. (6.1.1 (c) (i))
  • Fluid leak harmful to the environment or a risk to other road users diesel leak. (8.4.1 (a) (i))
  • Front Anti-roll bar linkage ball joint excessively worn Both fronts. (5.3.4 (a) (i))
  • Offside Front Anti-lock braking system component excessively damaged Abs ring. (1.6 (e))
  • Service brake efficiency below requirements (1.2.2 (a) (i))
  • Rear Brakes imbalanced across an axle Axle 2 (1.2.1 (b) (i))
Monitor and repair if necessary (advisories):​
  • Offside Rear Vehicle structure is corroded but structural rigidity is not significantly reduced arch. (6.1.1 (c) (i))
  • Brake pipe corroded, covered in grease or other material (1.1.11 (c))
  • Front Suspension arm pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
  • underbody corroded.
I agree, looks like a very poorly maintained vehicle.
I have never had an MOT failure on any of the vehicles I maintain.
To fail the MOT test, the defect has to be 'below' the minimum standard.
I would never let any safety critical component get anywhere near the minimum standard, never mind below it.
I expect someone will buy it.
