You don’t say what van you have as that can determine what you can load into it and also what your rear axle capacity is? Our garage will take a maximum of 350 kg with back axle of 2500kg.GVW 4500kgWhat is the rule of thumb for garage payload as my m/h has a payload of 700 how do you determine ideal weights for garage.
You should be fine. It only becomes a problem when you start to use it as a 'garage' and brim it with a scooter and the kitchen sink.
Be aware that every kilo in the garage will reduce the load on the front axle by a few grammes. (It's all to do with moments.) There's not much you can do about that, except that I keep the wine in the front on my return from France. You need weight up front for better traction as well as stability. Either way is not likely to kill you (but, if it does, only once).
