oh i guess you have discovered some of the practical aspects of the difference between various filament formulations. Some important components are;
ASA is Acrylonitrile Styrene Acrylate
ABS is Acrylonitrile Butadiene Styrene.
SAN is Styrene Acrylonitrile it’s like ASA without the rubbery Butadiene so is stiffer and more brittle.
There are also nucleating agents or chain extenders added to the polymer that change how the material crystallises and contracts during cooling — essentially chemical additives that make the shrinkage more uniform and reduce the internal stresses that cause corners to lift.
So the basic components are:
Acrylonitrile (A) Provides chemical resistance, hardness, and heat resistance
Butadiene (B) Provides toughness and impact resistance. A rubber phase dispersed through the matrix The weak link — the double bonds in butadiene are attacked by UV, causing weathering and yellowing
Styrene (S) Provides rigidity and processability. Makes the material easy to print and gives a good surface finish. Relatively cheap, lowers the overall cost of the blend
Each product, often just called “ASA” or “ABS” will have combinations of these things.
Looking at a couple of the technical sheets for the filaments you mentioned:
Sunlu ASA seems to be a relatively pure formula of ASA.
Where as, eSun ABS+ is ABS with SAN added in and a warp modulator.
It is probably due to the lack of SAN and/or modulators in the Sunlu that makes it harder to make warp free large prints.
I can’t be more specific because the technical sheets are a bit vague on some of the filaments you have tried.
I can show how SAN modifies the performance by comparing two eSun products:
eSun ABS. and eSun ABS+
Property eSUN ABS eSUN ABS+
Tensile Strength 43 MPa 44.9 MPa +4%
Elongation at Break 22% 3.9% -82%
Flexural Strength 66 MPa 74.8 MPa +13%
Flexural Modulus 1177 MPa 2492 MPa +112%
Impact Strength 29 kJ/m2 18 kJ/m2 -38%
HDT 78°C 89°C +11°C
Density 1.04 g/cm3 1.06 g/cm3 slight increase
Look how flextural modulus goes up by 112% with addition of SAN but the elongation at break has gone down by 82%
The SAN has made the filament easier to print (it’s more rigid so resits warping when cooling) but it has lost the toughness the rubbery Butadiene gives the pure ASA.
you have now reached the limit of my A-level chemistry!!!
In summary when you find a good filament stick with it - it’s not the not the brand that matters!
HDT 78°C 89°C +11°C
