..... they all seem to be 3500kg and 5500kg gtw so that only gives me 2000kg towing ......
I have been told the exact opposite of that but it was in relation to a commercial vehicle so could be different, or just wrong.It was my understanding (gleaned from a discussion with a police officer) that GTW - GVW is not NECESSARILY your max towing weight.
You must NOT exceed either of these weights. Providided that you don't exceed individual axle limits, you may distribute the weight you carry how you see fit.
In other words, you could run your vehicle at 3 tonnes and tow 2.5 tonnes and remain within your 5.5 tonnes GTW.
Ian
The plated weights are the only thing that you can be assessed (weighed) against.
The only weights displayed on the plate are:
MGW
Front axle weight
Rear axle(s) weight
Maximum Train Weight
There is no display of maximum towing weight - that appears separately on the trailer.
Ian
OK its the Camping and Caravan Club but this is my understanding.
Gross trainweight (GTW)
is the maximum weight a vehicle can move on the road as stated by the manufacturer. It includes the vehicle’s own maximum loaded weight (MAM) and the weight of a trailer and load. Sometimes referred to as Gross Train Mass (GTM)
Martin
I don't believe that the above contradicts my stated understanding?
Ian
OK I'm just saying its not just the legality of the vehicle combination but the licence could be a limiting factor. For example lots of big MH on IVECO chassis are plated at 7200kg or even 7495kg with up to 2000kg of payload thats OK if you can borrow some payload onto a trailer but falls down if your licence allows maximum train of 8250 and if the work it out as vehicle MAM plus trailer MAM, its not joined up thinking.@funflair , I've not looked into the details of the licensing requirements so can't really comment other than to say there is no reason why they should be linked to how overloading issues are assessed.
As you say that the trailer all up weight is about 2500kg, is it time to maybe re-think the trailer and contents to reduce the weight.hi I'm looking to buy a motorhome as I race jetskis ,problem I have is I have a huge box trailer and need a motorhome that can tow about 2500kg ,any ideas on which ones can as in style,chassis like Iveco sprinter ect ,any help I will be greatful as pulling my hair out here
many thanks carl
And what rule will they use to ascertain compliance?i can state with absolute certainty that if DVSA pull you over they will check the plate on the vehicle for MAM and train weight and the MAM of the trailer to ascertain train weight compliance. then they will weigh the motorhome and trailer
