So, I've now got a large gaslow, white filler etc setup and was originally planning on fitting the filler in the skirt, however on closer examination its going to be way too flimsy when the gas gun is hanging off it! So, exploring options rules out an in locker filler with bracket as I don't need even the thought I could get refused somewhere for opening the locker door, plus my locker is a bottle in front of another, not side by side, so extra hassle.
That leaves the last option which is the filler fitted to the locker door. The kit has enough stainless hose for this option to ensure that its not under stress when open or closed however I've thought of a possible logistical problem thanks to the thickness of the door itself which is approximately 4cm deep.
This presents a problem. If you look at the first picture with the filler all together you can see the metal filler extending at the right angle from the rear
but if I seperate the filler housing to the rough 4cm spacing it would be fitted? then the right angle is within the housing and no way the hose can be fitted to the end?
My initial thought is to cut a notch where the red mark is to allow the hose to be fitted?
Or is there another option? Tagging Basildog hoping he may have a thought too?
