New controller need , which one (1 Viewer)
955matt
208
130
bexhill on sea
Since 2012
Our solar controller has just stopped working , so I'm after a new one ,
Any help and recommendations would be great . It's for a Burstner Elegance 2010 with 2 solar panels .
The old controller is a Alden SPS180 wired into the EBL
andy63
4,672
15,017
south shields
None
since 1990
Sorry no real recommendation.. I've used mppt controllers that photonic universe supply.. they are still working..
And the one techno mentions in his posts on solar..
As long as you get one that handles the output of your panels it just depends on what bells and whistles you want with it... ie what information you want it to dislay and functions you want available. .
There will be loads mentioned in the various threads...
Have a search and a read through..
Andy
Lenny HB
53,321
149,523
On the coast in West Sussex
Hymer B678 DL
This is a very been using one for a few years as have loads of other Funsters. Only single output so you need to fit a solar split charge relay to charge the engine battery, I wired mine all via the Elektroblock.
andy63
4,672
15,017
south shields
None
since 1990
That's the one lenny has linked to above....
I fitted that in the chausson. .. no problems so far..
Andy
Aug 6, 2013
11,951
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If you wire via the EBL it will charge the engine battery without any additional wiring or facilities.
Lenny HB
53,321
149,523
Hymer B678 DL
Only if you fit a dual output regulator or a single output one with a solar split charge relay, which is what I did.
955matt
955matt
208
130
bexhill on sea
Since 2012
Went to Silverstone and the solar was great 6 days no hook up working well, next weekend nothing coming from the solar , checked the fuses etc all ok. Disconnected the panels and tested 21.5volts, check the controller output , no change if the panel was connected or not just battery voltage at the output cables. Disconnected the cables and left the panels connected nothing
Feb 21, 2016
4,916
29,400
Uk
C class
Since 2017
The Fat Controller;)
andy63
4,672
15,017
south shields
None
since 1990
Just to be certain if you haven't already done so... disconnect everything.. panels and battery...
Reconnect battery first then the panels...
Aug 6, 2013
11,951
16,556
Kendal, Cumbria
since 1999
Not in the case of the EBL99. The solar connection pin is simply another source of charging current and is offered to the battery sensing circuits along with the rest.
Lenny HB
53,321
149,523
Hymer B678 DL
Don't think so the Schaudt regulators are dual output and the EBL99 has no charging control on solar the solar connections are just straight through to the batteries.
Aug 6, 2013
11,951
16,556
Kendal, Cumbria
since 1999
I'm arguing this based on the circuit diagram of the EBL99. You are correct that the output of (whatever) solar regulator goes directly to the hab battery. So does the output of the EBLs built in charger. A sensing circuit determines when the hab battery and hab services are satisfied then allows the starter battery to connect to the hab battery - which is how the starter battery obtains a small, intermittent, charge.
I can't say I'm absolutely certain because life's too short to work out the detailed operation of the EBL and anyway I don't have information on the operation of its internal module. But I can't see a separate trickle feed within the circuit - hence my description of how it appears to work.
Lenny HB
53,321
149,523
Hymer B678 DL
That happens on the mains side but like I said the solar connections are just a link to the batteries.
