why does a water heater that's in all vans either electric or gas not scale in weeks?you still need a plate to plate heat exchanger or a calorifier and a pump trying to run it as a direct water heater it will scale in weeks
Pump is already includedyou still need a plate to plate heat exchanger or a calorifier and a pump trying to run it as a direct water heater it will scale in weeks
Watch the video ?What sort of noise does it make, me and my son both have the diesel heaters that came with the ambulances and they make too much noise for sites.
It says video unavailableWatch the video ?
Click the underlined bit where it says watch on youtube ?It says video unavailable
It says unavailable here watch on YouTube,It says video unavailable
Click on the tab that says play on youtube near the top.It says video unavailable
MmmmmmRRP £175 Propex 10L water heaters run off low wattage 240V electricity, easily obtained with solar and an inverter. Easy to fit water heater.
Understandable conclusion BUT is it correct? Time and the experiences of users will tell.It’s Chinese so it’s probably sub standard.
I worked from home doing an on call system for my last decade of service & the ambulance was parked outside my bedroom window, it snow's a lot where I live, so the heater was often left on, the noise was horrendous.What sort of noise does it make, me and my son both have the diesel heaters that came with the ambulances and they make too much noise for sites.
Looks like it will be a great addition to van builders and those that don't want to splash out on the likes of a Truma-D6 at £2500..
This will set you back, including £28 import duty if they catch you......
£305...
£305...
Hay guys, I've just bought that exact heater off the guy who reviewed it! David McLuckie. I’m going to build my own storage tank with a 230v 1,000 w electric heating element, plus 12v 300w heating element running off a dedicated solar panel for retaining heat and the deirddl heater will be plumbed in as off grid back up. My initial thought was to literally pump the tank water through the heat exchanger direct but having just seen the rust in the inlet and outlet pipes i thing i may have to pass the water through a coil and have radiator rust inhibitor solution in that system. To me what i can see in the instruction manual is its meant to be plumbed into your vehicle cooling system and used as a pre heater. David McLuckies channel spends a lot of time trying to make camping showers out of old webasto diesel engine pre heaters. My quest is to finish the job off and integrate it into my cheapo self build sprinter camper van. I’ll have video in a few months to show it fitted and working. Im sceptical any Chinese deisel heaters are any good but but i got it off him half price so its a disposable product if i cant make a Frankenstein style hot water system for my van!! Stay tuned!
£305...
Check out my vid and see how I'm going to overcome the problems attached to this controversial heater. David McLuckie reviewed it, but I'm going to fit it.
Cheers Karl.
I did consider not posting this on here, its just a quick 3 min vid to gather interest and open potential dialog as to how someone else would set it up but its not being received in an enthusiastic way so i will try and take this down and soon post a serious vid showing people how i intend to set it up. I dont advocate ignoring me, thats just spiteful. Good job i have a thick skin and can laugh negative comments off.I really, really hate videos like this that leave you searching for the conclusion. He does not explain anything.
Suggest everone clicks 'ignore' on this guy.
