- Sep 9, 2021
- 331
- 896
- Autotrail Mohican S
- Have owned my moho for 2.5 years now
Just pressed the button on a little additions for the beast. An 11kg Gaslow system. Impressed with the fitted price of £470.
Got two 11kgs system……lasts a long time.Just pressed the button on a little additions for the beast. An 11kg Gaslow system. Impressed with the fitted price of £470.
I currently have 2x6KG calor bottles. I havent ever gone through two on a trip a single cylinder would be ok as its just me.Got two 11kgs system……lasts a long time.
I had a 11kg gaslow fitted but also kept a 6kg Calor bottle fitted as a back up.I currently have 2x6KG calor bottles. I havent ever gone through two on a trip a single cylinder would be ok as its just me.
I have thought about that. then i can get a regulator for my cadac so i can use the cadac at home as well as in the motorhomeI had a 11kg gaslow fitted but also kept a 6kg Calor bottle fitted as a back up.
Gives you more options.
i thought so. It is a guy that installed my solar panel last year.That's a very good price... isn't that cheaper than the system as a DIY fit? You should be promoting the seller!
Us too. The perfect combinationI had a 11kg gaslow fitted but also kept a 6kg Calor bottle fitted as a back up.
Yes hes mobile. Automate Uk based at Brant broughtonLocal to you?
Yeah he did a top job on my solar panel last october so was pleased to see them pop up on the approved installers . Always good to have people you know do good work do stuff on our pride and joyAh Rob, he installed my media system a few years ago, good guy well recommended
All this depends on wether you travel in Europe, or in the winter. If so a Gaslow, gasit, or alugas system makes sense.
We have such a system comprising of 2 X 11 kg refillable cylinders.
If you change the van within say 3. years it probably doesn't make economic sense.
Phil
I want to use a Safefill, but my gas locker isn't big enough to take one. Locker holds 2 x 6kg Calor at the moment. I don't think sites would appreciate me using a Safefill stood outside the van on a long pigtail. Ideas please?Gaslow, Calor, etc etc - all the cylinders are so damned heavy - its a pity Safefill haven't developed a refillable that can be plumbed in to an external filler. I have two Safefill bottles (10Kg and 7.5Kg) and they are great re-weight but can only be filled via the POL outlet connection.
DittoUs too. The perfect combination
Have you thought about two Gaslow 6kgs cylinders, with exterior filling point and exterior BBQ point?I want to use a Safefill, but my gas locker isn't big enough to take one. Locker holds 2 x 6kg Calor at the moment. I don't think sites would appreciate me using a Safefill stood outside the van on a long pigtail. Ideas please?
Seems Alugas cylinders are in very short supply right now.
I trust the chap that's doing it and he is on the gaslow approve installer list so should know best practiceThat not a bad price, best check where the fill is going because it’s probably easier for the fitter to fit it in the gas locker door but this isn’t the best place, due to pipe flex.
I know some will say it’s ok but Gaslow say it isn’t.
Totally agreeHe did solar on two of our motorhomes ….he knows his onions and is very reasonable
