Naughty Bollard!!!
JJ20
250
551
UK
Since 2016
Hi everyone
We just hooked up to a bollard on an aire in France and my reversed polarity light came on? Am I safe to "stay calm" ignore the light and carry on? o_O
MikeD
3,939
3,685
London
IH PVC
Since 2012
Yes - almost certainly.
But it does depend a little on how old your motorhome is. Our 2012 Autotrail did not really like working with the polarity being reversed.
But if you are on the European two pin plug just take it out, turn it 180 degrees and put it back. That should sort it out.
Feb 8, 2014
1,553
2,437
Sheffield
Eldis Majestic 115
Vans and tugs since mid 70's
I carry a spare connector wired incorrectly to get correct polarity - my bro lives over there and his EL is reversed. Our lead guitarist over there had a shock from it.
J
JJ20
250
551
UK
Since 2016
Life is too short to worry about reverse polarity, what you worried about the EHU point has an RCD your van has an RCD.
My thoughts exactly, and anyway I quickly forgot about the reversed polarity when a Frenchman drove his motorhome onto the grass and sank, he looks pretty angry right now lol :mad::mad::mad:
6,049
18,154
sleights
c class
Must have plugged into some but as we have no light never worried. Why not leave it and if its fine take the bulb out so it doesn't worry you next time!
PeteH
6,862
9,027
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
ASSUMING. You have regularly tested your RCD,:rolleyes: and it is functioning as the manufacturer intended. You are probably going to SURVIVE.:whistle: However the safest way would be to take action and change the polarity of your connection, either by use of a "reverse link" (short connector wired "Wrongly") or even opening the plug and swapping (usually Brown and Blue) tails. The issue should you have a defective RCD, would be your appliances if they had faults, could deliver a fatal shock.:( RCD`s have been known to fail!.:cry:. In my Experience, many Spanish site EHU`s have "iffy" wiring, and are not tested as regularly as the UK. I don`t know about French sites but have come across a couple of Aires, where the old 2pin plus strip earth plug needed the be turned 180 degrees. I assumed by now most of these would have been phased out?
