AMZCHEF Single Induction Hob, Portable Induction Hob with Slim Design of 4.45cm, 20 Power Levels and 20 Temperature Settings, Fashionable Black Glass Panel, Touch Sensor, Hour Timer, Safety Lock £38.99
Fire Maple Antarcti Stainless Steel Kettle 1.0 Liter Camp Kettle | for Boiling Water, Tea, Coffee, Freeze-dried Backpacking Meals | Portable for Camping Bushcraft and Travel £28.95 I'll have a look at the screw location. I saw a similar thread about Hymer, but can't find that nowHi, my high level brake light is now down to two LEDs so I'm thinking replacement might be sensible. I can see two attaching/retaining screws - is this a DIY job? Have any Funsters replaced this and do you know if it's a specialist part? Thanks in anticipation
Thankyou - I'll check. I've sourced a Hella replacement for £38 on eBay with the screw holes in the right place. When get the ladders out and take the old one off and swap, I'll check before unpacking.Are you sure they are LED’s? I thought mine were and when I took it out they were tiny 2 watt bulbs. Bought a pack of 10 on Amazon for £6
thank you - a connector would make the job easier but I assume the new one will need the connector adding, so a bit of soldering... or perhaps stevewagners bulbs idea will be more straightforward!I think you will find that if you take the scews out and pull on the cable behind the light you will find a plug to disconnect it.
There will be numbers on the back of the lamp
If you buy another hella one it will have a connector, but anyway you could easily fit a couple of wago connectorsthank you - a connector would make the job easier but I assume the new one will need the connector adding, so a bit of soldering... or perhaps stevewagners bulbs idea will be more straightforward!
We use essential cookies to make this site work, and optional cookies to enhance your experience.
