No problem with mine throughout Spain Portugal and France in April may and june this year,,,Still using it in the house at home,,BUSBY.Ours worked really well in Spain back in Feb/March try going to settings and carrier and do a manual search pick strongest signal usually works.
With my hauwai mifi, it sometimes says connect using utility interface, i have to manually connect by getting on the mifi homepage and logging in. something like 192.168.01 in the search bar on google etc.
Always works fine in the UK though, but using 3 abroad does disconnect a few times.
We are at Honfleur at present working fine hereThank you all for your help. At this moment still not working but after a couple of hours already spent, patience is at a low ebb.
You can activate abroad. Yes they (and others) limit use abroad to 60 days so if you are away for a while take 2.Am I right in thinking that the "3" sim only last for 60 days while abroad. If you want to last longer you must take two with you , BUT they must be both activated in the GB. I also understand that what ever is left on the sim it can be used at home.
colyboy
It's my understanding that it's only Contract SIMs that must be activated in the UK - and there is no reason not to, as you are paying by the month anyway.Am I right in thinking that the "3" sim only last for 60 days while abroad. If you want to last longer you must take two with you , BUT they must be both activated in the GB. I also understand that what ever is left on the sim it can be used at home.
colyboy
Mine was originally a 'knowhow' didn't work at all, went through several hours with helpline to no avail. works ok in uk. Now have an EEMiFi worked really well in Spain in October/November. John also had a 3 phone with him, rarely got a signal for wifiWith my hauwai mifi, it sometimes says connect using utility interface, i have to manually connect by getting on the mifi homepage and logging in. something like 192.168.01 in the search bar on google etc.
