DBK
In this thread I described my little project to build a radio
When I ordered the kit I knew the company was planning to bring out a much smaller version soon but I was too impatient to wait so I ordered the older model. I don't regret this decision as the first kit was a good opportunity to refresh my soldering skills for the new model.
Which is a lot smaller...
It basically uses many components from my first radio but they are much closer together plus the main board has a lot of surface mounted miniature capacitors and resistors already fitted to it.
On the forum for these kits there have been quite a few reports of problems with it but I suspect most of these stem from construction errors - this was a tricky kit to build in the sense you have to take a lot of care with the soldering iron so you don't remove a prefitted component while adding a new bit.
But mine works!
This radio is working in the 30m band (10MHz) and I've been able to be heard in North America on the 20m (14MHz) at this time of day but it will be interesting to see if 30m works better later today.
My Little Radio Project
I mentioned on another thread I was going to make a small radio I could use for sending and receiving morse code. o_O The following is offered not so much as a suggestion that everyone should be doing this. :) I would much rather be posting about trips made this year. But apart from a few...
www.motorhomefun.co.uk
But mine works!
