As mentioned I have a problem with code
P2453-7A
DPF TRAP PRESSURE SENSOR
OIL LEAK OR RUBBER SEAL
This brings on dreaded amber light, but I can clear the code. if I then take it for a run the fault doesn’t reappear until I switch off and then on again. I am convinced this is a sensor fault but can someone throw some light on these readings.
DPF Pressure sensor registers 5 m bar. But once engine cools down it’s 0
DPF Status. Normal Clogging. BUT
PF Filter 85.39%. This reduces to 69.18% after a forced regeneration. If 100% is full I haven’t got much left. The vehicle has only done 24000 miles but is 7 years old.
last regen was done 229 miles ago so 300 between is probably the norm.
Average distance between regen. 750 miles.
Finally oil degradation is 87.843% last oil change approx 3500 miles ago !! Shows 3500 to next oil change.
Am I right in thinking % is not the correct measurement ??
Finally if I keep driving without warning light on should I be ok till it gets to workshop.
Any help advice appreciated.
THANKYOU
P2453-7A
THANKYOU
