We have an Autotrail with roof mounted multi directional aerial but not picking up any channels. We’re in Scotland and was working fine in NW England. Should we be doing anything different than just pressing AQT on avtex tv?
Yes and the light is on showing power.I assume you have an active (powered) antenna. Have you checked it’s plugged in switched on getting power etc?
I agree 100%multidirectional antennae's are only good in strong signal areas , you should consider changing it for directional vision plus with built in signal finder .
They will work better in weak signal areas
That's normal. Can you share some photos?There's something wrong with it, there is continuity between the braid side and core centre on the aerial itself.
