Much needed advice to safeguard my van? (1 Viewer)
Midland Nomads
121
65
Warwickshire
Coachbuild
Newbie
Hi Funsters
Looking for advice on what routine you follow when purging,not sure if you blow or suck
Seriously though would appreciate your thoughts??
Dec 10, 2013
3,423
12,217
South Staffs
Pilote P740GJ
Since 2013
Can I just add that I use a compressor to blow mine out, I unscrew the shower head and connect the compressor to that. Set tap to cold, open all other taps on cold and start compressor, then do the same on the hot side.
PP Bear
7,802
28,749
Kent, UK
Auto Trail Dakota SE
I usually unscrew the end of the showerhose and then leave all the taps open........
Only in this case I left the blooming showerhose attached and the entire mixertap and hose froze solid.
Drain water, open drain tap for boiler/heater, run the pump to purge water and leave all taps open.
Take out all bottles of water, or anything else that could freeze, split and make a mess when they defrost.
Empty and rinse cassette and replace, but leave the blade slightly open as well.
Oct 12, 2009
10,657
23,642
A Class N+B Arto 69GL
Since 2009
If you have a submersible pump in the tank that has a built-in non-return valve take it off the pipe or pipe will not drain. Also shake the water out of the pump at both ends.
Geoff
Lenny HB
53,417
149,914
On the coast in West Sussex
Hymer B678 DL
Don't forget when leaving mixer taps open to leave them in the central position.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Shouldn't this be in the belly locker?.
All that sucking and blowing:rolleyes: and shaking at both ends?:rolleyes: Not to mention the purging!.:D2
