Mozzi screen Burstner T700 roof light
Manchester, UK
Burstner t700
Early 2019
Having issues with opening mozzi screen, can't seem to find a way to open.Dont want to force in case I break it.
The screen should pull down and unclip from the surrounding on the roof. Lubricate it all with a silicone spray
TONCAZ, that's the same screen as in my T680, you have to push up slightly on the rear bar (it has a finger groove right along it) that unhooks it from clips either side, then it should rewind itself under spring pressure. Don't just let go of the rear bar once you've unhooked it though, as the spring can make it shut with quite a snap.
Tried pushing up, still no joy, is this the same as yours?
It looks to be the same ? Here's a couple of closer pics of mine showing the little catch that you have to unhook
from.
