PJGWiltshire
Looking for some guidance.
I am researching the installation of a lithium battery. The 100ah lithiums are manufactured to the same size as my 80AH Gel batteries of which I have 2. Now working out how I use my van, a 120ah lithium would work for the amount of power that I would need generally with solar top up and then charge up on the move with the B2B. So by buying the 120ah it is only £50 more expensive than a 100ah.
Now the problem is for me is that 100ah lithiums can go straight into the battery compartment. A straight swap but 100ah is border as to requirements and to make sure that I have sufficient power I would need to buy an additional 100ah lithium (expensive).
As I said the 120ah would work but I cannot fit that battery into the van dedicated battery locker and I will need to move it to another locker less than a meter away.
Fitting the battery in this locker would give it plenty of room and I can if necessary add additional batteries in due course.
Thinking about connecting the respective positive and negative charge/supply cables these will need to be extended from the battery locker to the new installed position.
Would simple positive and negative bus bars be suitable and then the appropriate sized cables connected to the new battery in the new locker or will completely new cables be required back to the charger and new cable to the isolating switch for the supply from the new positioned battery.
I hope this is clear. In essence can you safety connect cables using busbars to extend the cables to the new battery by about 75 cm
