mouse in my van what am i gonna do
You could get a cat!!🤣🤣🤣🤣🤣
Seriously, set a trap or two then see if you can see where it’s getting in👍
Get a cat😜
Sorry couldn’t resist. We have permanent traps in ours. Old ice cream cartons with small hole in one end & bait in the box. Change it yearly. No mice seen so far. If you don’t use the van for sometime stick one in the engine compartment.
Mice destroyed a caravan over time. They ripped apart sofa cushions, made nests with them in wellies, etc. I think they pee tiny amounts along their trail, which leads others in, so wash the wheels/tyres with a strong detergent, e.g., Jays fluid or something tyre-safe, and any mud flaps, wherever you think they got a leg up.
I used some bricklaying mesh and a staple gun, looking for any entry points and getting them covered. For awkward holes, use metal scouring pads. Get a couple of powerful mice scarers in there. Spray lots of mouse repellent everywhere. Use humane traps - dump them a mile away. I did lose my temper and put poison down, but they crawl into the most awkward spaces to die, eg air ducts, and the stink lasted months. I had to use an ozone generator to kill the smell; it never went away. It was a a very old caravan, so I just got rid of it in the end. On the next one, I made sure I mouse-proofed it from the beginning.
Edit typo's
I do hope you have better luck than a couple we were on the Turkey tour with. By the time they gave in and poisoned their “mouse” it had eaten and drunk(a red wine box) so well it had grown into a rat :giggle:
A farmer in another van had already realised when he’d seen the droppings but didn’t dare mention it as he knew the wife wouldn’t have gone back in the van!
help any suggestions please
If your parked up for awhile, put traps around van on outside and in side baited with peanut chocolate spread ,
You could spread some flower on the suspected area where you it’s getting ,
Then blocked holes,
But I think if a mouse what’s to get it will find plenty of ways to in,
Good luck .
Ps check engine compartment/ air filter for nests as well .
Where you think it’s getting in that should of read
We have had them, fortunately discovered mostly in good time.
Went straight to normal traps, and were glad but sad to have caught the pregnant mum who had made a nest, ruined my best bath mat and we had to buy a new cadac bag. Try to use deterrents and regularly visit the van in storage, the old farmer who had it to start with had cats and no problems till he sold out.
In winter I use essential oils, mainly pepper mint, sage, eucalyptus but also laurel branches, and I put pepper all along the walls or cupboards and look which way the are going or coming . On the engine I put powder pepper + hot red pepper! Also next to the pedals and everywhere there are moves for them to get inside I put bits of an old tee-shirt I've cut and put drops of essential oils in them.
I don't' live any reachable Kleenex or cotton etc..
Hope it helps!
We used Peppermint oil when we were sat it one place for the winter, we also had a Terrier that would kill on sight.
On a quiet evening I could hear mouse or rat rummaging around in the engine bay!
I had "a mouse" in the van three weeks ago. I cleared out everything and set six traps baited with peanut butter. They caught 7 mice over the next four days. So assume you probably have a family. The traps that worked best were in cupboards where mice had been. None of the ones "in the open caught anything. Good luck!
As well as all the suggestions above we also surrounded our RV with lots of flashing Christmas lights laid out on the ground. Apparently they like to work under cover of darkness so with all the flashing lights it scared them off.
We also stuffed any holes/access points we could find with kitchen foil.
Using lots of methods together did the trick and chased them away.
We use peppermint oil dripped onto some cotton wool and put in several different places in the van.
I have done the same, and at the same time also use lavender oil and citronella oil too (but not too much of the latter), otherwise it can be overpowering. Upsides are that there is a constant pleasant smell in the van and there are no longer any rodents as they can smell it from outside and stay away. Initial visitors were removed via humane traps and relocated a couple of miles away. We have not had any problems since, A further advantage is that insects also appear to be discouraged too. We used to note that flying insects used to nest around the cab door seals in colder weather, but this has now ceased too. - Win-win!
Mrs R and i are sat in the kitchen as i write. A mouse just ran across the skirting board and dived under a radiator, neither of us even mentioned it😆 the pleasure of living in an old house with lots of animals.
Once the fox terriers wake up i suspect they’ll be removing that radiator though🤔
Most rodents will try pretty hard to get out unless it’s reet cold
... behind our bungalow, caught the same one six times before it gave up.
Or died in somebody else's less humane trap!!
Somebody should market cat hire so you can borrow one to get the mouse & then give it back.
Or a catsmell aerosol so you can just scare the mouse away. Are mice scared of cat smell? I would be.. 😅
Set plenty of traps, I caught 8 in my van in total.
They did make a mess and do love the insulation and wiring.
The buggers ate through my diesel return pipes which I replaced but then found that they’d chewed through the top of the diesel tank so had to replace that also.
The van was parked outside at the time but is now parked in its own garage and I am putting a few deterrents in there plus led floodlights with pir sensors at floor level which should scare them off.
We're in rural storage and found moving to another pitch further from the boundary helped. Also make regular visits over Winter if you don't use the van. Check the engine bay and turn the engine over. Don't leave any food, even tinned.
Intruders, even small ones, can do a lot of damage very quickly and it will be expensive to fix so don't be too sentimental
Get a cat
We had terrible mice trouble in the house, then a cat adopted us 12 years ago and those mice just disappeared, they can smell the cat and know that a cat is a real threat to their lives, works a treat.
I will not go into details of what it was like before the cat came as I know that there are some sensitive souls on the forum but lets just say that it was mayhem.
