Mounting Solar equipment on side panel.
Mallorca, Spain
Benimar sport 340
Benimar sport 340
Any advice please. I need to arrange a lot of solar equipment on an internal, outside wall (side panel). The walls are a thin plastic outer and inner, with a foam filled centre.
I need to mount about 25k of equipment.
Any suggestions?
Thanks.
You'll maybe have to ply board it first. What equipment?
Without going into why's or what for's
- have you considered making a frame to spread the weight onto the roof and chassis? A bit like you see sometimes on vans fitting double glazing etc?
That's what I was thinking Richard & Ann. I also thought that there might be a lighter option. I will edit the first post but it should have read 25kg. I know that Victron are expensive but it's not that bad 😁.
I was thinking of maybe a composition bourd that I could use adhesive to the existing side panel.
I'm just guessing though.
Thanks.
I didn't, to be honest MisterB. I was thinking of some kind of composite board, glued to the panel. I'll think about your suggestion too.
Thanks.
Imagine the force when you hit at speed a speed bump you hadn't spotted? Your 25 kg suddenly become perhaps 50 or 100 kg.
I would look to support something, whether a frame or a sheet, from the floor if that can be done.
Phenolic ply from the floor glued and screwed if possible, if not possible screws, just puraflex or CT1 on the back of the ply. As DBK says vibration and potholes will accentuate the weight.
Thanks DBK,
I completely appreciate what you are saying. That's what worried me, any downforce will multiply that weight and screwed to a panel build for light weight and insulation, isn't going to last 5 minutes.
I'll gave to do some searching for any light weight board, that's substantial enough to take that kind of weight screwed into it. 1 item is fitted with 5 screws abd weighs 19kg. That would be an expensive and dangerous accident.
Reactions: DBK
Thanks Raul,
I'll check out that ply, is it light weight?
I will have to bridge the propane cupboard but I could beef it up low down and then glue and screw to the side.
Unless I can find another place to mount everything, while keeping the weight down. I've never been so conscious of a couple of kilos before 😁.
As I mentioned earlier, vans carry far more than 25kgs on their sides with no problems, using an external 'skeleton' frame
The sheet carried down to the floor/ suitable structural base could have an arch cut out of the middle, like a bridge, this would help reduce the weight. Or core a series of regular holes out of the sheet, again this would reduce the weight and spread the load. Do you need to lose any wires in the wall before adding the sheet? If so, lots of measuring, and measurements as to their exact location ;) .
Mike.
Reactions: DBK
First things first, 25kg up high is more of an issue than 25kg down low
Get a piece of lightweight board and mount captive nuts in the back, so you can bolt the gear on. Then bond that to the inner skin. Nothing would move that in normal use
Reactions: DBK
I get that some people may think the OP is talking about mounting stuff on the outside wall, not to the inner skin
What's the existing surface, 4mm fibre board? If so a quality 6mm ply board bonded to the existing will be more than adequate, also easy to put a finished surface on to.
Mike.
That'll make it squeeze down some of them west country lanes ;)
Mike
That's true MisterB. Even the ladder at the back, is bolted through, with a steel bar across both bolts.
Mike.
Thanks BouncyBoatFolk,
That makes sense. I hadn't planned on hiding wires behind it but now that you mention it, it could help..
Thanks.
Is that meant to be the weight - 25kg, or the value of the equipment?
Kg... my error.
Thanks TheBig1,
That's a good idea.
Mike.
Thanks Mike,
Yes, it's about 3mm or 4mm and then the foam core.
