Martin Stacey
- Apr 22, 2019
- 35
- 36
- Mobilvetta Kea P65
- Since 2018
Does anybody know where to mount a second lesuire battery in a 2017 Tracker RB please?
Where's the first hab battery Martin - is it under one of the front seats?
That's what I did with my Autotrail Excel. Well secured, and vented via a tube teed into the original battery vent.Andrew The 1st is under the floor and accessed from a hatch under the dinette seat. I did think about getting a battery box and mounting the 2nd battery in the space under the same seat but wondered if there as a better solution? or if this is a safe option.
Hi Martin Stacey , I too have an Autotrail Excel (670B) and when I purchased it from new I requested amongst other upgrades a 2nd Leisure Battery. This was placed under the Habitation seat next to the oven with the battery box sighted next to the dividing wall between the seat locker and oven. A good choice in my view as the distance between both batteries was negligible resulting in minimum cable length between both sets of batteries and the vent tube from the second battery could be fed down into the first battery box compartment and out of the van through the dedicated vent holes. Later on I fitted a shunt and a blue tooth battery monitor and the sighting of the second battery box made this an ideal location for fitting the additional equipment. I have also wired in an Inverter to the leisure batteries. The Sargent Charger will take up to a 220 AH lead acid battery bank, so doubling up will not be an issue. The plastic battery box was screwed directly to the hab locker floor and has not moved from new. Simples!That's what I did with my Autotrail Excel. Well secured, and vented via a tube teed into the original battery vent.
