Motorized waste valves (1 Viewer)
Dec 31, 2010
2,635
5,822
Sunny South Shields
Frankia Platin i7900
Thinking of adding this to the van, I know I am bored stiff and looking for another project but if any one is interested these are a excellent price on Amazon.
DN40 Ball Valve DC 12V G1-1/2" Brass 2 Way Motorized Actuator Valve for Air Conditioner and Plumbing Amazon product ASIN B07KW5ZYXT
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Beat me to it Lenny
Sep 10, 2012
2,131
3,706
worcester
Sunliving van
Bought the last one. Can some tell me what I need switch wise to wire it up?
Oct 29, 2016
4,504
52,691
Surrey
Carthago C Tourer
Well done Ditcha, let us know how you get on with fitment & waste pipe fittings/adaptions.
We have had a knackered waste dump vale in our van from new, long story, but our dealer will have to drop out the entire grey waste tank to fit a new dump valve, and is not sure if the long operating lever between floor will become unattached again.
The operating lever attachment to the dump valve is in a very tight position against the side of the tank & between floors, its not possible to get it reattached in a secure way, so I was thinking an electric non mechanical option would be better option in the long term.
Will be watching to see how you get on.
Good luck.(y)
LES
Ditcha
Dec 31, 2010
2,635
5,822
Sunny South Shields
Ditcha
Dec 31, 2010
2,635
5,822
Sunny South Shields
Good luck.(y)
LES
Les I am just going to use the motor from the valve and mount it on top of the waste tank to actuate the valve already there and get rid of the naff tap under the doorway floor that you had problems with
Oct 29, 2016
4,504
52,691
Surrey
Carthago C Tourer
I think you will need a 2 way switch, and some 3 core cable + neutral feed to valve actuator.
Perm live feed to common terminal.
L1 connection to open valve.
L2 to close valve.
There should be a wiring diagram/instructions inside the valve box.
LES
Sep 10, 2012
2,131
3,706
worcester
Sunliving van
" These are great for emptying while driving along, especially when you’ve got loads of cyclists behind you..."
But only if it's raining so it just looks like your going through a big puddle :ROFLMAO:
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Or one of these ----
consider the current required
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=402466309063
stevewagner
1,814
4,039
Pevensey Bay
Yonks
Only IP50 so will need protecting from the elements.
