Murrayclan
- May 12, 2021
- 7
- 5
- Burstner maybe
Its a Burstner SolanoHello and welcome
whats the make and model of the motorhome ?
Is it a Bailey ?
My problem is whether this is particularly low or is it normal? I don't have anything to compare.It could be a problem having a steep drive ours is steep and then bottoms out at the road, we’ve always had high chassis for this reason.
Ours is also 2.1 from the centre of the rear wheels to the furthest point at the bumper. That’s not excessive at all.My problem is whether this is particularly low or is it normal? I don't have anything to compare.
Thanks , does it restrict sites you can access?Sounds pretty much identical to our Hymer
I have fitted air suspension so I can lift the rear by a good few inches, hopefully just before I need it, or after grounding
as said above also very good for ferry loading especially the smaller Scottish ones
Edit - just thought I would measure mine
2.8m overhang from wheel centre and 0.3m high under chassis
Is the 0.3 to the rear bumper David the lowest point of the bumper?Sounds pretty much identical to our Hymer
Our chassis is much higher than the bumper so the opposite of yours. Never too much notice until now.
There are plenty worse. Ferry ramps in particular will have you wincing. You probably can get some air bags in place and pump them up when you think you might ground. We did this and it worked well. But the cost of those made me wince tooThanks , does it restrict sites you can access?
Someone on here simply bolted some nylon trolley wheels on to the chassis extension
Not necessarily if the wheel only slightly protrudes but of course you are right as always. I never said it was a good idea anyway. Not something I would do as have plenty of clearance and a shortish overhangAlways a great solution; not!
If you want to increase the frequency of grounding (and increase the stresses to boot), it’s the way forward; not for me though.
Ian
Thanks, really appreciate your help. Love the MH and hope it is the way forward.We have a 2010 Burstner Solano.
We have "bottomed out" about 5 times in as many years. 3 times on Scottish ferries and twice (believe it or not on the entrance to Lidl car parks in Europe)
It's was a shock the first couple of times but it has never done any damage to the MH.
I have never had any problems on sites at home or abroad
