Hi all. After squeezing down the slimiest road and on backing up to a facing vehicle we hit a wall!!!!! To avoid where possible that happening again can you recommend a good MH GPS please? Lesson learnt! Many thanks.
Interesting, not seen that before. Presume you are happy with it? Wonder if the IOS version would run on an ipad that has gps???
Slimist!!!Hi all. After squeezing down the slimiest road and on backing up to a facing vehicle we hit a wall!!!!! To avoid where possible that happening again can you recommend a good MH GPS please? Lesson learnt! Many thanks.
It's the best of ones I have tried that accommodate being able to input the size of your vehicle, but as with all the others, it's not perfect.Interesting, not seen that before. Presume you are happy with it? Wonder if the IOS version would run on an ipad that has gps???
Thanks, I just sent a query to their technical asking if I could use it on a gps enabled ipad & got a personal reply within 5 minutes!It's the best of ones I have tried that accommodate being able to input the size of your vehicle, but as with all the others, it's not perfect.
I don't specify the exact size of our MH to the last mm, I add a couple of foot all round.
Not taken the wing mirrors off down narrow lanes and streets yet.
Thanks for all the sound advice and wisdom. Will take all on board and look into recommendations.I tried Co Pilot Caravan but it still sent me along ridiculously narrow lanes, no better than Google Maps. I now check out the questionable parts of my route using Google Street Scene.
I'm on Android, but see no reason why a GPS enabled ipad will not work fine.
Sygic Support Center | How can I make a purchase in the Sygic GPS Truck & Caravan Navigation app - iOS?
Our Support Team has prepared this brand new website to better serve you, all aimed at delivering the help you need as quickly as possible.help.sygic.com
Do a forum search, there are as many opinions as there are satnavs.Hi all. After squeezing down the slimiest road and on backing up to a facing vehicle we hit a wall!!!!! To avoid where possible that happening again can you recommend a good MH GPS please? Lesson learnt! Many thanks.
That’s what I run on my iPad mounted in my pop up holder on the dashboard.Interesting, not seen that before. Presume you are happy with it? Wonder if the IOS version would run on an ipad that has gps???
Similar things have happened in much much much smaller places particularly in the dark evenings, don't ask me how I know, I just do.I feel your pain! Similar experience in Paris. Just don’t take the vehicle into cities anymore unless absolutely unavoidable or known route
It’s why we decided not to travel at night unless absolutely necessary.Similar things have happened in much much much smaller places particularly in the dark evenings, don't ask me how I know, I just do.
Wise words duly noted. Many thanks. I’ll do some digging around and also invest in a good road atlas !!What works for me at the moment is my old Tom Tom 510 with my newer 10" android infotainment unit running Waze in tandem. With all the threads that have been discussed on this subject over the years I figure there is no perfect system but what you are most familiar with is lightly to be the best navigation system for you.
If you have an android tablet/infotainment centre you can try out almost all the major players apps and see what works for you because quite honestly I think a sat nav is much like a wind tunnel if you put the same shape in and blow air over it your going to come out with pretty much the same result.
I tend to use my Tom Tom as the main unit because I am familiar with layout and in times of stress my eye is always drawn to the relevant information. I turn the sound off on the Waze unless I feel the Tom Tom is taking me in a direction I feel is not the optimum for me, in which case I can compare notes with the Waze and if required change to the Waze.
The main thing I would say about any sat nav is do not rely on it totally no mater how good your system is. If your gut feeling is telling you "That right turn road doesn't look right" then your gut 99 times out of a hundred is probably right.
