More Battery questions... (1 Viewer)
Jan 19, 2020
188
522
DBM 7150
Since 2016
Yesterday's question related to the traumas of getting the seat out to get at the leisure battery, todays are a follow on..
When I took the battery out it was measuring 13.14 V this morning only 12. 7 V so I am assuming it is crackered?
I checked the van this morning, no leisure battery connected but there is an alarm sounding. I didn't disconnect the engine battery, so I reconnected the leisure battery while I source a new one but the alarm stayed on, any thoughts please... It wasn't sounding for the 6 hours yesterday after the leisure battery was disconnected.. It seems to be coming from the solar panel controller which is a Teleco.
The old battery is a Varta AGM, replacements readily available. If I was to go to GEL who are the recognised reliable makes..
Thanks again
andy63
4,672
15,017
south shields
since 1990
Thanks again
Think you are jumping to conclusions without really knowing for sure.. you say the battery is done but the voltages you quote are not conclusive and a result of a charging source been present and then 12.7 is stil l a good voltage..
You really need to check the capacity of the battery with a known load and see how it preforms before reaching any conclusions about it..
The seat removal you mention frightens me now... my back gets bad just thinking about it(y):LOL:
Andy..
Sep 25, 2012
522
1,228
West Cornwall
13 Years, 20 years with a caravan
Firstly if your battery was tested at 12.7 after at rest for some time I would say its still good. As far as the alarm is concerned you need to follow this rule if you have solar.
1 Connect your battery(s) first.
2. Connect your solar second.
The controller will then recognise your battery.
When disconnecting.
1. Disconnect your solar first.
2 . Disconnect your battery(s) second.
My personal preference is Hankook for my leisure batteries as they have always served me well. Other people will have their own preference. I purchase from Battery Megastore but there are other good suppliers.
Hope this helps.
Phil
P.S Some solar controller's require you to input your total battery(s) amp hours on initial set up.
Apr 27, 2016
6,853
7,948
Manchester
A class Hymer
Since the 80s
A full battery, after disconnecting from any charging sources, will gradually drop to its resting voltage, which is about 12.7 to 12.8V. The 13.14V reading means that something was charging it (solar?) so the battery voltage is not a good indication of the state of charge.
The only way to test a leisure battery, if the voltage looks OK, is to apply a load and see how long it keeps supplying the load. For example, a 100Ah battery should supply 5 amps for 20 hours. If you load it with 5 amps and wait 10 hours, it should be down to 50%. Disconnect and wait for the voltage to settle. If the voltage is 12.2V then the battery is OK.
Sep 17, 2017
5,415
10,105
Birmingham, UK
A-Class
12.7v overnight looks fine to me. Van is currently on the driveway.
Mine has solar. Once the sun goes down, it drops to 12.9v and slowly degrades overnight. Even with almost no load. I think this is normal.
(The big flat spot in the middle of yesterday was me disconnecting the monitoring system, so no updates for a few hours.)
WJACC
Jan 19, 2020
188
522
DBM 7150
Since 2016
When disconnecting.
Hope this helps.
Phil
Thanks for the above
Please excuse the basic questions...
When you say connect/ disconnect the solar, is that from the electrobloc or direct from the panel?
Andy..
The problem I've had with it is I went through the tunnel last week, so for a maximum of an hour the battery wasn't being charged by the engine or solar and after 40 minutes just powering the fridge it tripped out. Now from fully charged it will trip just powering a few lights after a few hours.. Similarly with the TV, it lasts a couple of hours.
So I'll disconnect the solar, switch the fridge on and see how long before it is discharged..
andy63
4,672
15,017
south shields
since 1990
It does sound like the battery is low on capacity..your most probably right replacing it..
The fridge does represent a fair load and most probably around 120w..but even taking into account that that sort of load will lessen the batteries nominal capacity if its failing in less than an hour. hope its all sorted soon...and the seat goes back without causing you pain (y)
Andy..
WJACC
Jan 19, 2020
188
522
DBM 7150
Since 2016
A little test this afternoon. Solar disconnected completely. No EHU etc.
At the start battery reading 12.9V. Switched on antenna and tv only, ran for 2.25 hours before tripped out. 10 minutes before it stopped battery reading 11.3V... 15 minutes after tripping battery read 12.7V. After I put the antenna down only 12.3V...
I don't know if I'm further forward or not....
