Madcaravanner -they are great. Much better than the gaslow dial on the cylinder which I find drops to the bottom of the red zone when the cylinder is still 1/3 full. Work using ultrasound I think. Just apply the monitor to the bottom of the cylinder (magnetic so fine with steel cylinders) and link to your phone wirelessly. Worth every penny.
At this moment in time - - unless I can find a UK based seller it's on the back burner most I can find have postage costing as much as the monitor and I would need 2
When I bought it it was cheaper from the USA but Autogas2000 and Gasit sell them I think. Couldn't you just use one on the second cylinder in a 2 cylinder system?
I bought mine from Gasit. They work well on 6kg Gasit cylinders, but took a bit of trial and error to find the best location on the bottom of the cylinders to get a good reading.
