- Feb 5, 2024
- 1,158
- 2,444
- Etrusco CV540 DB
- On and off for about 30 years
To give some background, deciding on a suitable bike rack for our 5.4m Ducato based camper was a difficult process. I originally favoured a tow bar mounted type which leaned back to allow the barn doors to be opened, but realised that these things are very heavy to maul around and also stick out a very long way behind the van and do so at a low level which makes parking difficult. In the end I opted for a Thule Elite XT door mounted rack even though its 35kg load capacity was going to be marginal for our two electric bikes, though was fine for the two conventional bikes we had to start with. The new electric bikes were chosen accordingly - one has a carbon fibre frame, and the other, a folder, is aluminium, so with the heavy batteries removed and stored in the van they are just under the limit.
The first trip with the electric bikes on the back was a 3300 mile circular tour of Scandinavia. Part way into the trip I noticed the that the horizontal load supporting bars which are clamped and glued to the door had shifted slightly and the adhesive seemed to have stretched and was becoming visible above the bars. This had been installed according to the instructions and using the recommended Sikaflex adhesive so this was a bit alarming. We had been over one particularly rough mountain pass in Norway which had turned from tarmac to gravel for about 20km, and some sections had a very bumpy washboard surface, so this may have caused the problem. I decided to monitor it closely but took the precaution of buying an electric drill and some bolts so if necessary I could drill through the bars and the door and bolt the two together.
Anyway, the thing held together for the rest of the trip, but when we got back I decided to take it off the van and investigate what had happened. I will post some pictures below. I found that the adhesive had almost completely separated from the back of the bars which were only being held on by the clamps at each end. Interestingly the adhesive was firmly bonded to the door and in fact was a a real job to remove, but had come away cleanly from the grooved sections on the back of the bars where you are supposed to apply the adhesive. Not impressed with this - it seems that whatever paint or surface treatment Thule apply to these grooved sections is like teflon so far as the adhesive is concerned! It took me about two days to carefully saw through the beads of adhesive on the van and then remove the thin layer this left behind. The only tool that worked for this was one I made from an old white plastic ruler - the purpose made tools and solvent I bought were completely ineffective.
I took the inside panels off the door to investigate the feasibility of bolting the bars permanently to the door skin and found that this looked to be possible with enough access to get at the back of the bolts. I decided to reinforce the inside of the thin door skin with some right angle aluminium bar which is much more rigid than flat bar. I used three 8mm bolts on the top bar and two on the bottom bar. On the top bar I also used two brackets to connect the right angle bar to the inner door metalwork. This was not needed at the bottom because the inner and outer panels are already bonded together with a big bracket. I only used adhesive on the back of the bars around the bolt holes, mainly to ensure they were sealed against water ingress, and tightened the clamps as per a normal installation. Quite tricky to ensure that all the holes lined up but I managed to find a way to do this.
The other thing I wanted to achieve was to have the bikes set at a lower level. We originally set the wheel rails at a height such that the van's lights were not obscured so we didn't require a lightboard. However this meant loading and unloading the bikes was pretty much at the limit of what my 70 year old body could manage! I really didn't want the complication of a lightboard, and while the folding bike with its small wheels could fit between the van's light clusters, even with the rails at the lowest possible level, my bike with full size wheels could not. The solution I eventually decided on was load my bike with the quick release front wheel removed. I made up a plate to fit on the end of the outer rail to take an axle/fork holder such as is used on some roof mounted bike racks. I found I could secure the front wheel below the bike rack rails by replacing the securing straps which lock the rack in the open position with longer ones intended for the wheel clamps when used with fat tyre bikes, and wrapping these around the wheel before going through their clamps.
Overall, hard work, but I am well pleased with the result. This bikes are now so much easier to load and unload especially after drilling extra sets of holes in the uprights to mount the folding rack section as low as possible. Incidentally this reminded me of another design flaw with these racks. The hinged rail section pivots on two bolts with the nut retained for each in a hex shaped aperture in the plastic hinge covers. The first time I tried to undo these to change the height of the rack the nuts just turned in the plastic moulding making it impossible remove the bolt and there was no space around the recessed nut to get a spanner or socket on it so I actually had to destroy the plastic mouldings to get at the nuts, meaning I had to buy replacements. I solved this by buying some longer bolts and stainless spacers which sit in the recesses ensuring that the nuts are accessible.
Hopefully these ramblings will be of some interest to others! Pics below.
Part way through removing the old adhesive and showing how it had not adhered to the grooved sctions on the back of the Thule bars
Inside of door
Part of the upper fixings
Lower fixings
Fixings from the outside
Axle fixing plate
Showing left and right side light cluster clearance
Inside of door
Lower fixings
Axle fixing plate
