Missing switches on new Hymer ?
Basildog
1,248
1,066
We have an Alde booster heater under the passenger seat (RHD) Hymer manual says it is 2 speed and switched at side panel of seat but no switch is fitted but I have found wiring so maybe the switch was never fitted ?
Also have an Alde auxiliary pump next to the heat exchanger under drivers seat but again no switch like stated in manual ?
Also front heating is really not getting hot like everywhere else is this common on Alde or something that needs attention ?
icantremember
7,785
15,350
Near to Watton in Norfolk
Hymer T-SL668
since 2005
We have both the booster and heat exchanger, both of which are controlled from the Alde panel .. although there is a valve next to the h e which controls the flow of fluid.
This may not be much help to you as it seems that Hymer fit every model differently and infact often different vans of the same model.
It took me quite a while and some experimentation to get the whole system working correctly.
The only switches we have on the seats are for the seat heating.
Sep 26, 2011
3,308
7,109
Spalding LINCS
A Class Carthago
Since 2008
The seat switch on our Hymer is on the bottom at the right hand side of the passenger seat and the pump switch is next to the control panel but we have never used it as it only warms the engine from the van heating.
Sep 26, 2011
3,308
7,109
Spalding LINCS
A Class Carthago
Since 2008
@Basildog
Basildog
Basildog
1,248
1,066
Yes yours are exactly what the Hymer manual says, we definitely don't have any :(
Basildog
Basildog
1,248
1,066
How do you find them on the control panel as might be worth me looking ?
Ours is a 2017 B778
