Mirrors again? (1 Viewer)
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
How the hell do these come apart, as you can see, they need a bit of tlc but cannot see how to get them apart???
funflair
19,199
29,887
Guisborough
MORELO palace
since 2012
Give them a good thump underneath and they should slide up and off.
martin
wizzer59
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
funflair
19,199
29,887
Guisborough
MORELO palace
since 2012
Ours are a bit newer but come off with the heel of my hand but you could try a block of wood and a firm but not too heavy smack with a hammer(y)
Just in case I will add that half the black bracket stays on the van:LOL:
Martin
Aug 6, 2013
11,941
16,533
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Mmm still solid:confused:
Hammer technique: get a helper to rest a lump hammer on top of the body bracket then use another lump hammer to hit the mirror bracket from below. Use thin cardboard, if anything, to protect the bracket from the hammer blow.
funflair
19,199
29,887
Guisborough
MORELO palace
since 2012
Mmm both bits still on, was hoping to get them off and spray paint but it looks like that's not going to happen so on to plan b:)
Buy a newer Hymer with none tatty mirrors ;)
I you want them off that badly it looks like you might have to remove them from the inside of the van and then get the bracket in a vice or something so you can give it a smack without the van attached.
Or buy @Robert Clark 's Carthago(y)
Martin
Jul 18, 2009
11,036
17,482
Manchester UK + Javea/Xabia Costa Blanca Spain
HYMER B644
Same mirrors, same problem but I took the easy road, cleaned them up without removing, rubbed down with wet and dry, then hand painted with Hammerite smooth satin back
That was a year ago and still look fine
post here https://www.motorhomefun.co.uk/forum/threads/hymer-mirror-arms-rusting.131415/
Great Job Jim
Ours have electric cables but not connected in Hymer.
wizzer59
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
Thanks for that,(y) that did work in the end but had to use a sledge on the top:confused: and lump on the bottom, not easy when the top is only 15mm thick:confused: will put some copper ease on when I put them back together, hopefully that will stop them fusing together:)
