Mirror help
carthorse
Gods own
Sunlight T67s
Getting the hang of it
Getting the moho ready to set off to poole docks tomorrow, wiping the dash I knocked the rear view mirror off (it has the rear camera screen mounted on it).
Now I've just spent 20 minutes trying to refit it and can I hell like get it back on.
There's a bolt head attached to the windscreen and three arms inside the mirror housing anyone had similar and how did you fix it please.
Should say it's a Ducato base.
Lindsay
Put it above the block on the windscreen and slide it down towards the dashboard.
Thanks will try that now
Right fixed it,thanks for your advice landy Andy it didn't go back on that way had to turn the arm to five o'clock push it over the bolt head turn it and it snaps back on.
Panic over
Lindsay
Good to know carthorse !
I took my mirror off last year, for the life of me I couldn't reattach it for fear of breaking the windscreen!!!
Does it just slide on with no pressure at the 5 o'clock position? Then 'twist to lock'?
Yes that's right turn and it snaps back on very easily no real pressure needed ,it had me scratching my head seams easy when you figure it out.
Lindsay
