Destination Unknown
- Oct 30, 2010
- 398
- 835
- American A Class
- Not Long Enough...!!
Anyone have one or used one. Any good ones to look at and ones to keep away from.
How long do they stay charged for out of interest and what is the actual charging time to 100%VCAZ is correct, NOCO is an outstanding piece of kit.
I bought the GB70 12V 2,000 AMP. (starts 8.0L Petrol or 6.0 lt. diesel engines).
We travel all over EU and this gives that security that you will never be stuck with a flat battery.
The NOCO Boost has a wrong connection fail safe, just anoth thing to recommend it.As long as you connect up the correct order. I have never had a problem.
Yup, £200 for something that’ll do the business or considerably less for something that might....Looks great but £200?
Provided you have another vehicle or batteryI prefer jump leads, always ready to go.
Alternatively you could go for a Noco genius, which is a smart charger only but will charge and I believe condition batteries including lithium, but does need to be connected to 230v.
With the NOCO Boost HD GB70, can it just be connected to the starter battery to top it up? I just want to take a starter/charger out to the storage site every couple of weeks and charge the starter battery without turning the engine over. I will of course take the van out of a long run also but wanted the backup of knowing the starter battery was fully charged as the tracker and alarm are off that battery also. The leisure batteries are at home with a charger. General consensus is that it is a jump starter only. Thanks.
Ok I am no expert, but the noco genius, is for gentle charging and conditioning, and can be left on for months eg all winter, and will be good to go when you need it, unlike cheap old battery chargers many did not have a cut off and kept charging and boiled the battery dry. but a knackered battery is always going to be knackered.I am probably going to fall foul of some wizardry electrical calculations which will state the Ah rate is not correct to charge a starter battery, only boost/jump. It seems an off-grid charger pack doesn't exist.
