Microwave rattle (1 Viewer)
pvsdb
18
6
Scotland
Bessacarr E460
New
Still a bit of a novice at this makarkey so a lot to learn still. Been working front to back reducing rattles from the blinds (Remis? mostly fixedby tightening screws and packing with cork tabs), oven and oven door and using non-slip sheets on cupboard floors, drawers etc. I'm getting there but te microwave is a problem. It is inside a frame but isn't fixed so every bump causes it to clatter by lifting and falling. There is a flexible plactic vent frame but I cant see how to get that off to pack the gap between the top of the microwave and the frame. Any ideas appreciated, thanks.
Nov 7, 2015
497
469
Newport, Shropshire
Autosleeper Broadway
since 2015 previously caravaning 25 years
Ours has 4 screws through the shelf and up into the metal base of the microwave near the 4 feet. Good idea to remove the case of the microwave and have look inside before inserting any screws !
P
pvsdb
18
6
Scotland
Bessacarr E460
New
Thanks, I'll look tomorrow.
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
Hi, Ours was like that but I just rolled up two pieces of that non slip matting and made sausage like packing under the feet never rattled again .(y)
Emmit
8,034
17,751
Cornwall
Pilote Explorateur
Jan.2014
Our microwave is a 'Post Manufacture' sat in place of the TV.
In order to prevent 20Kgs hurtling through the van in the event of an accident, I put two 'L' brackets on the back affixed to both the bottom of the van and the rear of the Microwave utilising existing fixings.
Underneath, and forming part of the base of the equipment are two pressed steel feet. I have used Sixaflex to 'Glue' the feet onto that part of the 'van that the feet are located.
Every now and then I give the Microwave a vigorous shake to test the adhesion and it ain't moved in four years.
Eenansue
Banned
Apr 23, 2018
67
275
Brizzle at the moment
Limited experience
Make sure you don't block the cooling holes otherwise you might resolve ALL your rattling issues (once the fire service have finished)
