But its front wheel drive surely better to have them on drive wheels?Best tyres should always go on the rear particularly as these will have more grip than your standard tyres.
Nope, the back end will always break away first hence best tyres should be on the rear. Also you should not mix Alpin rated tyres with standard tyres. Best to replace all 5 so the spare matches.But its front wheel drive surely better to have them on drive wheels?
Nope, the back end will always break away first hence best tyres should be on the rear. Also you should mix Alpin rated tyres with standard tyres. Best to replace all 5 so the spare matches.
Thanks thats interesting Ive just read a good article that explains it well. SteveNope, the back end will always break away first hence best tyres should be on the rear. Also you should mix Alpin rated tyres with standard tyres. Best to replace all 5 so the spare matches.
EditedTypo in there (missing NOT) I think!
Ian
Should you fit new tyres to the front or rear?
You’ve bought a new pair of tyres, but here’s a question, should you fit your new tyres to the front or rear?kumhotyre.co.uk
Not when you consider that retreads are legal, but not recommended to be fitted to the first steering axle.It’s funny that they will put retreads on the rear and new on the front of an hgv and not necessarily the same make.
