Hi all,
We are in sunny Spain, well wet Spain and have been experiencing some problems.
1. As we drove from Valencia to Denia everything was great when the following stopped working, the vehicle is a Eura Mobil based on a 2003 Fiat Ducato
A, heater
B, wipers
C, electric windows
D, radio
E, cigarette lighter
F, external thermometer
When we got to Denia I checked all the fuses and all were showing to be fine, I then stripped the dashboard down and found no loose connections all looked good I did some research and found that this is a known fault, it transpires that fuse 31 in the left hand fuse box for the computer services had failed causing these faults. I changed the fuse and everything started working again.
Yesterday we drove towards Gibraltar when we got to Estapona all the above started to switch off again, I again changed fuse 31 and low and behold everything again worked however when we got to our overnight stop the fridge was going crazy I.e. Lights flashing, a relay in the habitation electrics clicking like mad so I pulled the fuse only to find it very hot and the socket it fits into slightly melted, the fridge seems to work fine on 240v and gas yet not on 12v.
has anyone experienced this?
I should add the fridge was fitted new just before we left 28th October.
Thanks in anticipation
Bob
A, heater
B, wipers
C, electric windows
D, radio
Bob
