Mercedes 2002 Rapido 2.7 LTR , 5 cylinder
twinchy
Mark
2002 Mercedes rapido 2.7 ltr , 5 cylinder
My Rapido is losing power as it goes uphill. Does anyone have any ideas ?
Too little info to tell but one educated guess is an EGR valve fault, this will certainly manifest itself when going uphill.
The copper injector sealing washers can go brittle & cause problems but usually it'd misfire with this fault & sometimes smell of diesel.
The 2.7 5 cylinder lump is generally regarded as one of Mercedes best diesel engine.
Oh & if you give us an idea where in the country you are its easier for forum members to help or advise one another.
When my 5 cylinder Sprinter lost power it was the turbo boost valve which costs around £90 from MB or half that price for third party type. Simple to fit oneself.
Thankyou . Am in Crowborough in East Sussex. So it’s an A class camper. If it is one of those valves , where would it be found in the engine ?
blocked air or fuel filter?
Could be several reasons, does it go into limp mode, does it keep changing gear or stick in third, any yellow lights on etc. Is it a Sprintshift?) On my last van, which has the same engine, after much expense and changing many parts in turned out to be the hydraulic pump on the gearbox (the Sprintshift is a manual gearbox with a hydraulic change.) Also check the 60 amp fuse under the drivers seat.
