measuring leisure battery voltage (1 Viewer)
Mar 2, 2011
506
986
uk
c.. autocruise starblazer
8 years
The habitation control panel in our MH has simple needle readout dials for water and batteries , showing incremental empty, quarter//half etc . No voltage/amps etc shown for batteries . Apparently the needle readout dials are not particularly accurate and a more precise battery state could be of benefit.
Until we get round to delving into long term solutions for actually maintaining battery power , would one of these things give an accurate enough voltage reading for hab batteries , when put in one of the hab area 12 volt sockets fitted in MH ?
Two on Tour
10,321
50,908
Elddis Autoquest 175
Since 2010
We use one of those on our last motorhome to give us an idea of the hab battery voltage and is a low cost simple solution.
I have now fitted a fancy bit of kit in our present camper which give more detail on battery percentage, amps/watts usage etc.
T
Mar 2, 2011
506
986
uk
8 years
Thats the way forward for us as well. The plug in battery voltage detector being a basic interim measure . Recent problems with our diesel heating actually highlighted the requirement for monitoring an accurate readout on hab batteries status ...As well as deciding to fit , in the near future , appropriate "gadgetry " to maintain engine and hab batteries at optimum levels ........ Am at the start of the delving around for gadgets :)
Vanman
1,665
3,916
Runcorn
Roadscout R PVC
March 2017
The trouble I've found with these sorts of gadgets / meters is that they don't 'play well' with electrical equipment. If you have a solar panel fitted then even an empty battery will show 13-14v whilst it's charging. It's only an hour after everything else has stopped putting in, or taking out, that you can get a 'proper' reading. Hard to achieve when you are using the vehicle.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
They might look accurate but unless you can check against a decent voltmeter do not trust one, says a man who bought a couple and although a good quick check they were not very accurate.
T
Mar 2, 2011
506
986
uk
8 years
Points noted and accepted folks.
As briefly mentioned above , am looking for a interim workaround until moving on to fitting more accurate means of maintaining and measuring battery status...... That will no doubt be in another thread topic from me in the near future
8,945
18,699
Corby, Northants
Coach Built
You may want to consider what your long term aim is rather than your short term aim in order to save money.......in the long term.
Many experienced motor homers fit a 'shunt' and appropriate meter which measures the true state of the battery and in particular, how many Amps are being taken out, put in, (at any given moment) and, how long to fully charge the battery and how long before it's discharged. One of the problems you will encounter when using a Volt Meter with reading a battery when the battery is in use, is that you will not get an accurate reading. This can only be achieved when there is no charge going into or out of the battery and it has been rested for a few hours. However, saying all that, a volt meter is better than nothing. Should you decide to go down the route of fitting a shunt, you will get loads of help from U Tube videos and fitting instructions are usually comprehensive and one can do it themselves. They even have Bluetooth models available now so no drilling and routing of cables to the display case. An example below.
http://www.nasamarine.com/product/bm-1-bluetooth/
Dec 10, 2013
3,423
12,220
South Staffs
Pilote P740GJ
Since 2013
I have one of those gadgets which I bought before I had our solar panel fitted and it is within 0.1 of a volt to the actual reading on my panel.
T
Mar 2, 2011
506
986
uk
8 years
Weve only just taken the MH on a PX for our previous MH and the short term aim isn"t to save money , its until we get round to delving into long term solutions for actually maintaining battery power .
IE the gadget I showed the link to , is to have a basic and interim solution of even rough measurement of battery voltage . Which is still a lot better than our present innaccurate needle meter % system . This until such time as the onboard electrics have been fully checked out and appropriate modifications /additions decided and made to improve the batteries ( engine + leisure ) charging/conditioning /monitoring .
EG at the moment the solar panel only has a mono charging PWM regulator , so looking to probably changing that to MPPT dual .Also maybe fit a B2B charger or voltage sensitive/sensing relay etc .
As another measure of conserving power, am at the stage of ordering up LED to replace the halogen and PL fluorescents which are in the van at present and eating up battery power like no ones business .
Davylambretta
94
49
Ayrshire
Laika Ecovip 7R
Something like this any good to you if you look about ebay you can get them cheaper
43,323
49,433
As you have a solar panel fitted the gadget in your opening post will be useless in daylight as it will show the solar charge voltage, not the true battery voltage.
The same applies if you're on hookup...charger voltage, not battery voltage.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Battery and solar / EHU charger voltage are always the same. Voltage at rest is only available at the battery terminals with everything disconnected and then only after a period of stabilisation. The arrangement suggested by the OP used intelligently will do the job.
Vanman
1,665
3,916
Runcorn
Roadscout R PVC
March 2017
Hmmm. My Solar panel outputs a whole range from 0 to 14+ I suspect that the only places they are constant is very sunny places in daytime and the dark side of the moon ;)
As soon as the solar input exceeds the battery level then I believe a simple meter will only show the higher of the two.
43,323
49,433
Yes, but only if ALL charging sources are turned off....including the solar charger.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
If the meter is on the output of the solar regulator then it is reading battery voltage no matter what the solar panel, or any other charging source, is doing.
Vanman
1,665
3,916
Runcorn
Roadscout R PVC
March 2017
That's not my understanding of how it works ... if the battery is receiving power then it is that power that the meter will show, if the reading is taken off the battery or any circuit directly attached to battery o_O:confused:
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
How what works? I am talking about using a simple digital voltmeter (or a multimeter) to measure voltage. If the meter is connected across any pair of wires, anywhere in the vehicle, that are connected to the battery positive and negative terminals, then it will read battery voltage. I am deliberately avoiding complicating the issue by not mentioning the effect of wire resistance and the voltage drop it may or may not cause.
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
im sorry to say you are wrong with my engine running it will show alternator output and when stationary it will show solar input only after dark will it show battery voltage and then it needs up to an hour to stabilise
Jan 19, 2014
9,385
24,755
Derbyshire
Elddis Accordo 105
since 2014
I suppose it's down to what you mean by battery voltage... The voltage across the battery terminals is different to the battery's resting voltage, which can be used to determine the state of charge.
Jan 28, 2008
10,116
18,382
Renalt burstner
yes thats correct you need the resting voltage i couldnt think of the correct word for it
Dazzlin
1,751
6,213
La Marina, Costa Blanca.
1986 Hymer A Class
From 2013
Ours has never run out. Hook up about twice a year but keep an eye on batt charge and state via BM1. 2 x AGM's & 4 x solar (another thread)
Bring it on....
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
I mean by battery voltage - Battery Voltage. The conditions under which it is measured will change the value of the voltage but it is still battery voltage. I made the point about measurement at rest earlier in the thread.
Jan 19, 2014
9,385
24,755
Derbyshire
Elddis Accordo 105
since 2014
All we're doing then is wording it differently, but I don't think it's helpful to talk of battery voltage when measuring the solar charging voltage (which happens to appear across the battery terminals). I would say "voltage across the battery" but each their own.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
I agree it's semantics but it's important that there's no misunderstanding. The lowest resistance source (the battery) is what determines the measured voltage. It is influenced by what is connected to it (or not) but that is still what you see with your meter. Last week l helped friend who's solar system had stopped working. He believed that a meter across the solar regulator measured the output of the panels and a meter across the battery measured the battery voltage. So when he saw nothing across the regulator and 12.6v across the battery he thought his regulator had failed. He didn't realise that whether the solar regulator was working or not he should expect the same reading at both ends of the cable that linked it to the battery. (The fault turned out to be a parted connector in that cable).
