Can anyone hear something?If I did he wouldn't listen, men never listen.
Yes he does.Trust me, he does not need anymore tools.
A new tape measure ???Yes he does.
He needs a tool to help him drill in the correct place
HE'S NOT ALLOWED TO MAKE ANYMORE HOLES Andy, now please behave yourself, you may enjoy it.Yes he does.
I couldnโt agree more. I think ALL tools should be removed from him, especially near the Moho.HE'S NOT ALLOWED TO MAKE ANYMORE HOLES Andy, now please behave yourself, you may enjoy it.
He IS the biggest tool.I couldnโt agree more. I think ALL tools should be removed from him, especially near the Moho.
Non-Dremels currently in Lidls, ยฃ19.99. Comes in a case with a flexible drive and work light.
Need does not equal plus one where X is the present number of tools ownedMadam, may I refer you back to my post #28 (it's not our fault, we're only men)
As such the number of tools we men NEED is N + 1 where N is the number of tools we already have
Oh yes he doesTrust me, he does not need anymore tools.
Oh you think so do you......we will see about that.Oh yes he does
A man always need tools.Trust me, he does not need anymore tools.
Should read 'A man always needs more tools'A man always need tools.
Give the man time to buy more tools.Ok, more than 24 hours without an update on progress. Did you resolve it? What did you end up doing?
The WiFi is rubbish in the.........doghouse.Ok, more than 24 hours without an update on progress. Did you resolve it? What did you end up doing?
The OP was concerned that using a spacer would reduce the length of thread retaining the clampYou could design a spacer in a CAD system like design spark mechanical if you take accurate measurements from that base piece with callipers and also include a profile for a cutout for the quadrant corner piece and the desired thickness and then 3D print the spacer in white PLA.
Anyone with a printer could print a spacer in about an hour and when fitted, it will look like it was designed to be that way rather than a bodge because of a slight measuring error.
The 3D printer is your friend.
So is this antenna designed to fit only one thickness of roof? The OP didn't mention that, so I would assumed the manufacturer would have accommodated different roof thicknesses into the design of the antenna. But perhaps not?The OP was concerned that using a spacer would reduce the length of thread retaining the clamp
He isn't getting one...The 3D printer is your friend.
I can report that he was making noise out there, including the vacuum cleaner.Ok, more than 24 hours without an update on progress. Did you resolve it? What did you end up doing?
Those cheese pasties can make a hell of a lot of crumbs, while your sat watching the telly, if your not carefull.I can report that he was making noise out there, including the vacuum cleaner.
I never understood algebra till explained in the number of tools I need is N+1.
