ambulancekidd
- Sep 23, 2014
- 10,365
- 28,388
- Swift Kon-Tiki 640
- Since 1964 Gosh that makes me feel old.
I've spent ages trying various DAB aerial options on our motorhome with various levels of success, but I still wasn't happy.
So to that end, I decided to fit the new Vision Plus 570 aerial in place of the near to useless Status flying saucer type.
The new aerial comes with a diplexer especially for DAB, sounds ideal.
I measured the placement of the new aerial about 40 times, but still didn't get it quite right.
I eventually took a bravery pill & got on with the drilling, oh pants, first casualty was a cable buried in the roof insulation, much gnashing of teeth with weeping & wailing ensued. In my defence, I couldn't have known that it was there.
It turned out to be the power cable for the toilet light & electric flush, so no major worries there.
Well no option but to carry on, the hole was drilled, so I applied a healthy dose of Sika-Flex & fitted the mounting which I screwed down firmly.
Looks ok, so I popped the aerial in the hole.
Then to the inside, I discovered that the hole wasn't quite where I'd measured it, this is more like Destroy It Yourself than DIY.
The hole was very close to a baton which holds up a cupboard, so now I can't fit the inside supporting bracket without further modification.
Now I need to work out what to do next, all suggestions will be gratefully received.
On a happier note the TV & DAB reception is flawless.
