Maxview crank-up, not so good in the wind. (2 Viewers)
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
It's fairly sheltered where we are, windy but not stormy.
Do I expect too much.. I don't think so, the mechanism isn't man enough for the job.. Roof doesn't flex, it's made of plywood
Don't underestimate wind, Mr Fish did.
If they improve the lock then something else breaks. They fix that, something else breaks. And suddenly your roof can't take the weight.
scotjimland
scotjimland
2,255
9,774
A Woosh bang
Do you have a Maxview Crank Up Brian ?
If not then your hardly qualified to say whether it's fit for purpose or not, as far as I'm concerned the lock and cranking mechanism isn't fit for purpose, forget the wind .. it's a crap design, end of story.
Alden, Camos, Wingard, and a host of others don't suffer from this, and it's not only the wind, the design is flawed, the mechanism is held in place with a single spring clip.. if it slips ( and it will) the cranking mechanism is liable to fall on the floor while travelling.. see previous poster..
Dai Motorhome
151
19
Burnham on Sea, Somerset
a class
Thank you to all the people who have posted here. i'm looking for a crank up system at this time, and certainly won't be looking at Maxview products given the opinions expressed here.
cheers
David
Sep 3, 2009
1,532
6,275
NW Surrey
LHD Hymer exsis-i
Just seen thisand couldn't resist posting. IMHO the rotating dial.windup mechanism is one of the worst examples of industrial I've ever seen. Just two very small moulded plastic lips to hold the ceiling unit in place! When it falls out as it usually does, it's a real pain to reinsert. I wouldn't recomend Maxview to anybody
Malcolm
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
cheers
David
David, Did you find a good quality crank-up dish?
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
Thanks Jim. Probably best I start a new thread. Sorry for hijacking your other thread regarding sat dish system :oops:
scotjimland
scotjimland
2,255
9,774
A Woosh bang
no probs.. good luck with the search..
if you want a hand crank, I'd look at the Camos Crank-up
Broken Link Removed
Emmenay
505
481
Swift Kon-tiki 600
Since 2011
Is it possible that Maxview have ironed out this issue.
I recently bought the next generation 85cm crank up, and its maiden voyage was Devon and Cornwall in what i can only describe as 'bloody windy weather'.
There were no issues whatsoever even though the mh was rocking in the wind. The only reason I put it down in the end was because I didn't want to rip a dustbin lid sized hole in the roof!
I am now in Costa blanca with it and can receive the usual sky stuff on the wider beam albeit very low qulity signal but still watchable.
Nov 2, 2008
461
377
Lincolnshire
PVC, S&L Iveco
45 years
We have the Camos crank up and it seems to be less effected by wind due to its shape. I was also told that the crank mechanism was a heavy duty American unit. Ours is about six years old and used for up to 1oo days a year and has had no problems but it is now getting a bit sloppy and worn.
