Maxfan (1 Viewer)
Trout bum
567
584
Ayr
Adria Matrix M670SL
Has anyone replaced there sky light with a maxfan ?
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Thanks for reply but more looking for someone who has changed there original skylight for a maxfan on their Adria motorhome ,
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
Is there a specific reason that it has to be an Adria?
I have replaced our skylight (mini something) with the maxxfan deluxe. Is there something specific you want to know?
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
It's to see if it will fit existing skylight with no cutting , and somewhere I read that the Adria,s were pre-wired for roof fans , so was hoping someone on here had undertaken this task to see how it went
Oct 9, 2019
4,945
17,272
Todmorden
Van conversion
FUNSTER in a PVC
Possibly it’s because according to his avatar, that what drives ?
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
If you identify the existing sky light we should be able to tell you if the fan will fit. Mine was straight remove and fit the maxxfan. No extra cutting etc required. Given that most skylights are a common component for all motorhomes you may be in luck. (just checked ours was a mini heki delux 400 x 400 roof hole)
If you go ahead there is an article, I think I posted a link to it, taking one though the installation without the need for screwing on to the roof which I was not happy with.
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
I'll measure it and see if there's any identification on it , I'm sure I read somewhere that the Adria motorhomes had been pre wired for a roof fan this would save running a cable to it
11,953
16,567
Most small rooflights are 400 x 400 - I'd be surprised if yours is different. If you remove the inner frame the size & whether it's pre-wired should be visible.
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Thanks for the info I'll give it a go and see what I find
