Manual slide door step
Northampton
Rapido & Bongone
I am concidering a manual door step or modifying a running board eg vanpimps fox.
How do you use a maual retract step? Pull out from inside and retract lock in after use.
Is a running board enough space. Any advice from self makers modifiers, how to mount.
I have a rapido coach built the panel from cab to body is lower than door.
Before anybody mentions electric, swmbo is from Yorkshire ( how xxx much). Its 3 years gone before shes allowing me to concider a manual one
Hi, i would also consider a running board type one, as electric fitted will be almost a grand?
I share your questions though?
We had a manual slide out-step (not a Thule) under the side sliding door on the PVC we bought which was a pain with the jumping in and out to slide it out and slide it back in again, it was very quickly swapped for a Thule electric slide-out step.
I still have the old manual slide out-step which you're welcome to if you want to convince your wife of how useless it is. :giggle:
No thanks, offer appreciated,
what feels like many moons ago i modified the Vanpimps fox running board. Does the job a treat
Looks good - where do you get these boards from - easy to fit?
stylo2000 As mentioned Vanpimps
see thread from #15
