Making the change from lead acid to lithium - a thread with pictures (1 Viewer)
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
So, after being lucky enough to get a lithium battery for less than half price, (thanks Jim), this thread will be the process for how I have changed over.
I may be talking to myself a lot but that’s okay, I always search for rubbish like this when I do anything so I am hoping it will help in future.
I have a Hymer with a decent split charge relay. Currently have 350 watt of solar via a Votronic MPPT. That has a lithium profile so all good.
I will however need a B2B so again going for a Votronic model. Partly because they have clear instructions and will work with the EBL Hymer install.
I am going for the 30 amp model.
<Broken link removed>
I would like more but in full sun, the solar can pump out 15 amps and the maximum charge capacity of the lithium is 50 amps.
I have 200ah of lead acid. Payload is tight and the extra capacity of lithium means I can take a 100ah lithium down to 10% giving me only 10ah of usable power less than the lead acids. I don’t think I will need two lithium’s and at £700 each, probably just as well.
I will post pictures as I plan and rip out the old stuff.
Dec 2, 2019
3,579
7,739
Amersham
van conversion
Since 2019
If you did well with 200ah lead, the 100ah Li will be sufficient and a improvement. The charge efficiency is almost 100%, meaning you don’t have to put in more than you took out with the lead.
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
Only ever nearly run out once.
I didn’t realise lithium charged more efficiently too. Happy days!
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
This is my current setup, space is tight and to be frank, it’s a mess!
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
Not far for the invertor, 1200w PSW. The cables where it connects though seem to get hot at full whack so will be re doing those connections too.
You can also see the Votronic MPPT which I will be moving to inside the battery compartment where there will now be room after ditching the second battery.
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
It’s one way of fixing the battery down, but not one that I would do. 😳
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
Always match your lead acid batteries. Erm, not like the previous owner of my Motorhome.
Mar 23, 2018
416
606
East Devon
Since 1995 + 20Yrs a 'Tugger' first.
Just gone to clean up the compartment by switching the inverter on for the vacuum. Yes I am stupid! 🙄
Yes, just the sort of thing I do. Like wringing out the cloth I've used to mop up the under sink when I'm replacing the sink waste! Good luck with this. Following with interest.
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
Just realised that the old solar controller I have won’t be compatible with lithium.
I have two, one for a 250 watt panel which I installed which is the Votronic and the older one which doesn’t have a lithium setting and is connected to a 90 watt panel from when I got the motorhome.
That’s annoying as I will also need a temperature probe for a new Votronic controller as well as one for the controller I already have.
As reluctant as I am to spend another £100, a 90 watt panel will help top up the lithium in the darker months and as all the cable panel are there, I may as well do it properly.
Sep 16, 2013
2,219
7,908
Horncastle, UK
I have a Votronic 430 with the temp cable that I need to sell if of use?
Only used it for a few weeks (changed my panels and needed higher VOC), cable still new in box.
a5436
Dorset, UK
VW California T6
Hello, long time lurker here, but following with interest. As a drop in replacement, does the Eco Tree need a lithium profile, or will it manage the charge itself using a Lead Acid profile?
Do you have a mains charger that also needs a lithium profile?
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
It would work but is bigger than I need so not sure you would want to part with it for the same price I could get a smaller Votronic one? It’s a kind offer though if you just want rid?
It says drop in, but a battery to battery charger will protect the alternator and vehicle as well as give a higher charge rate.
With regards to the solar, I already have a lithium profile on one.
It would probably be fine, but I am not prepared to risk knackering a £700 lithium.
53,309
149,502
Common dealer method when fitting a second battery.
I agree. :rofl:
Your Votronic regulator will take 350 watts of panels so you don't need another one.
Sep 16, 2013
2,219
7,908
Horncastle, UK
Tbh I was scan reading and didn't notice the small one would sort you out.
Looks like your sorted anyway :giggle:
Good luck with your upgrades. I use the big Votronic B2B with my LiFePO4, have used Votronic MPPT's and fitted the B2B you linked to in another van. All have worked great (y)
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
I agree. :rofl:
Thanks Lenny, alas they are completely different panels. One is 250 and one is 90 I think.
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
Always good to hear other peoples experience of the kit and reassuring it worked as intended.
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
It's the voltage that maters not the power eg dont mix a 19V With a 39v, 48v version( nominal 12v, 24v domestic
I vaguely remember checking when I got the new panel. They are different voltages which is a pain.
I am sure that’s why I kept the old controller instead of bunging it all in the Votronic. Apparently from what I have read, they will work but the lower voltage panel will drag the higher one down and affect the performance by quite a margin.
Getting a new controller isn‘t a deal breaker, means I have redundancy if there is an issue and I can put a bigger panel on if the current 7 year old one expires.
I can say one thing, a proper system ain’t cheap! Lead acid or lithium. 😢
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
Disconnect the panels and measure the open circuit voltage on a bright day.
I did Lenny, I looked back through other postings I made and it jogged my memory.
Did it when I installed the 250w panel.
From memory, it was over 10 volts difference.
Googlebot
Sep 29, 2019
3,039
7,026
Hymer Exsis
20 years
That’s buggered it again!
Just checked the specs of my big panel, it’s a 275 watt and not a 250.
That means it’s too much for the one controller I have if I stick in the 90 watt as well.
250 and 90 watts ?
As above I am afraid, one is an old 90 watt and the other newer one is a 275 watt.
I reckon I can get a 150 in the place of the 90 watt though, so I might wait till the 90 expires and go that way.
Not easy this motorhome stuff is it? 😂
Dec 2, 2019
3,579
7,739
Amersham
van conversion
Since 2019
Count the cells on the panel. The 90w I guess is a 12v 36cells and the 275 is a 30v 60 cells panel.
Agree is cheaper to get another 275w panel, if controller allows.
