Hellski
I had run out of floor space within my Burstner Ixeo 680g garage but had some space above the bikes that was wasted, so this got me thinking.
First thought was to install a shelf but decided against this as it would be restrictive with the shelf being fixed and didn't really want to start drilling into the side walls.
Following further research on internet I came across ceiling storage solutions using plastic boxes but couldn't find anything available here in the U.K. I then came across 1" aluminium wallboard sections used in the building trade. I already had some plastic storage boxes that were a perfect size. The only downside was I had to purchase a 4m length (allowance for mistakes!).
Measured the length required to allow the storage of two boxes, cut, drilled and then fixed to ceiling of garage, which being the base of wardrobe is good solid timber to fix to.
This has turned out better solution as the boxes can be removed giving me more flexibility then a fixed shelf. Personally really chuffed with the result
Space gained within garage following the purchase of our folding bikes.
1" aluminium wallboard cut to size and fixed to exact width of plastic storage box to allow it to slide in and out.
Both boxes in.
Everything back in, bike rack slides in and out with boxes in situ, as well as everything else being accessible too and best of all approved by Mrs J.
Both boxes in.
